Need help w/ wideband install
Old Jan 3, 2008 | 06:09 PM
cobaltBlackss's Avatar
I'm installing a WEGO Wideband O2 sensor and I can't fugure out which wire from the MAP sensor to use. Has anyone installed one lately?
Old Jan 3, 2008 | 06:17 PM
NYC_Eddie's Avatar
Talking
i taking a guess here but im installing a aem uego too.. and i think all you need to do is wire it up for power ( make sure you ground the black wire) and have a bung hole drilled and welded on you DP before the catalaytic converter then connect the bosch O2 sensor that came with the gauge and run the wires back to the gauge. anyone can correct me but i think this is how you install it. hope this helps a bit
Old Jan 3, 2008 | 06:23 PM
My set up is a little different, it's from daytona sensors. The power, ground, O2 sensor, and rpm wires are all hooked up, I just can't figure out which MAP wire to use.
Old Jan 3, 2008 | 06:25 PM
NYC_Eddie's Avatar
aite cool..hope someone else can give ya some input.
Old Jan 3, 2008 | 06:26 PM
exiged's Avatar
um........... if its a wideband the only wiring you need to do is the + and - for power. Besides that you just plug in the o2 sensor and thats it.
Old Jan 3, 2008 | 06:27 PM
NYC_Eddie's Avatar
thats what i thought...maybe his isnt a wideband...prob a narrow band? i would advise you to double check your product to make sure its a wideband and not a narrow band gauge.
Old Jan 3, 2008 | 10:17 PM
The extra wires are not for the wideband itself. They are for the program that it comes with, hence the RPM and MAP wires.
Last edited by cobaltBlackss; Jan 3, 2008 at 10:17 PM. Reason: Automerged Doublepost
Old Jan 4, 2008 | 07:02 PM
DarrenGC
Dec 24, 2021 01:55 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
n20saturn
Sep 30, 2015 12:26 AM
