oil feed fitting size in block
Old Mar 28, 2008 | 08:06 PM
y2kzman's Avatar
QUOTE=BlackSS/SC;2112885][/QUOTE]
Can anybody tell me what size fitting needs go into the blue circle and where you got it. I need to go from whatever thread that is to an -4 AN fitting for oil feed. I have the oil galley plug out and it looks like a straight metric thread that is 12 X 1.75 but all of the metric to AN adapters I find are 12 x 1.5 or 12 x 1.25 it might not even be a 12 mm I am just compairing it to a tap I have in my tool box and they look the same.
Old Mar 28, 2008 | 09:55 PM
mike25's Avatar
youl need an m12x1.75 to 1/8npt
and autometer sells the adapter
Old Mar 29, 2008 | 10:18 AM
y2kzman's Avatar
thank you
Old Mar 29, 2008 | 09:59 PM
mike25's Avatar
Originally Posted by y2kzman
thank you
no problem
Old May 25, 2008 | 05:13 PM
NGalaxyTimmyo's Avatar
Just make sure to then get an 1/8npt adaptor to a -4an. I overlooked this and ended up with a huge leak and missing out on the event I was planning on going to for awhile. You can get both parts from summit racing as well. About $10 for both
Old May 25, 2008 | 05:14 PM
joeworkstoohard's Avatar
what sort of oil sender is -4an?
Old May 25, 2008 | 06:06 PM
y2kzman's Avatar
Thanks for the info. I did get both parts from Summit Racing i a working on getting my turbo setup installed now.
Old May 25, 2008 | 06:49 PM
mike25's Avatar
it doesnt have to be a 1/8 to -4an...just to whatever size the line is....mines -3an
EDIT: nm yea i have jic fittings
Old May 25, 2008 | 06:54 PM
Red07SSNA's Avatar
AutoMeter Part # 2278 (12mm male X 1/8 NPT female and a brass washer/gasket). You can order them through Autozone too. ~$15
Old May 25, 2008 | 07:17 PM
originaladrian's Avatar
qft...
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 13, 2015 09:32 PM
nathan112i
Sep 30, 2015 07:12 PM
