Performance Mods: Adding TVS
So finally I got a TVS thanks to dcoll177, good guy and good deal. (Super fast shipping!!) :twothumbs
Anyway, so far I have a 1. TVS shown below: (redish color due to loctite seal) 100_1435.jpg picture by jgarciarivera - Photobucket 2. Stage 3 Exedy Clutch 100_1313.jpg picture by jgarciarivera - Photobucket 3. Boost gauge up to 30 psi 100_1317.jpg picture by jgarciarivera - Photobucket 4. 80 lbs injectors 100_1422.jpg picture by jgarciarivera - Photobucket 5. Plugs 100_1423.jpg picture by jgarciarivera - Photobucket 6. Injector harness 100_1424.jpg picture by jgarciarivera - Photobucket 7. Belt 100_1419.jpg picture by jgarciarivera - Photobucket And my mods on my sig. Goal is 350-400WHP. My first stage is: Reading Which means learning about mods, parts, equations, CFM etc. I downloaded the GM handbooks. Also, this stage includes planning, and budgeting. Please, bear with me, I'm an Electrical Engineer, so I don't have that much skill has the people on this site. Second stage: Getting in shape my old 1986 toyota. Cobalt is my DD so I can't start mods until I have a backup car to drive to work. Someone suggested me once to put a 2JZ motor on it. :-D Also, I'm waiting for tax return so money is coming eventually. Third Stage: Complete planning, budgeting. Which means, a complete list of parts, part numbers, vendors. Logistics: what to do first, that is, best route for mods economically speaking. I will be slowly updating this thread, so feel free to add comments. For each part you guys suggest, I will be putting a list of the parts and the name of the poster. Power Race Parts suggestion- Do research :cssNET: 1. pecorillif - mid length to long tube header 2. Turbo Tech Racing (Vendor) - Upper Engine Mount and STOP Transmission Bushings 3. omnigear - Powell Rotated mounts 4. alleycat58 - ZZP header 5. sjc0013 - heat exchanger 6. rootbeer - phenolic spacer 7. rootbeer - 80 mm pulley 8. rootbeer - Griffin HE 9. jgarciarivera - ZZP 3" CAI 10. jgarciarivera - LS4 TB 11. zfissette - ZZP Stage 3 HE in series with radiator CSS.net references Exhaust https://www.cobaltss.net/forums/2-0l...ing-lsj-66344/ https://www.cobaltss.net/forums/2-0l...lt-ss-sc-6872/ Engine stats https://www.cobaltss.net/forums/gene...e-stats-26790/ Air management (CFM) https://www.cobaltss.net/forums/2-0l...j-parts-67539/ Thanks all Jose |
TVS = tits
:cssNET:
i would suggest getting a mid length to long tube header, tvs = more air, gmpp manifold = sux
Got it, added to the parts list. Thanks
are you gonna be running e85 or just91/93
Turbo Tech Racing Upper Engine Mount and STOP Transmission Bushings
Originally Posted by paintballerr78
(Post 6283084)
I can send some corn down there :)
Originally Posted by TurboTechRacing
(Post 6283091)
(Post 6283119)
Originally Posted by jgarciarivera
(Post 6283121)
That will be great! TTR for the win.
the real question is Aaron, is ita bushel on the cob or shelled? Lol a sad attempt at a joke I know, but Ive grown up on a farm and handled a bushel of corn in both those ways.
(Post 6283193)
Shelled is ~56 lbs, why ship a cob, unless he wants to put one up someones @$$ :lol: |
click
What size pulley are you planning to run? If you don't have access to E85 you're going to need meth [EDIT: or some other way to add lots and lots of cooling] to be able to run enough timing to hit those numbers.
This is my car: https://www.cobaltss.net/forums/dyno...5-dyno-246633/ Have since added a ZZP header, but did not re-dyno. Car needs some more work first. Bad coilpack makes it sad panda right now, but I have house mods to do first. |
Definitely a heat exchanger, unless I missed that and you already have one lol
<dual pass, option b, long tube, K&N cone filter, bkr7e, 60's, tvs(80mm), 93...needs more timing in the low-mid range but so far making around 275hp 235tq
i need a phenolic spacer |
Originally Posted by RooTBeeR
(Post 6283700)
Originally Posted by alleycat58
(Post 6283247)
This is my car: https://www.cobaltss.net/forums/dyno...5-dyno-246633/ Have since added a ZZP header, but did not re-dyno. Car needs some more work first. Bad coilpack makes it sad panda right now, but I have house mods to do first. About Meth, well, we'll see what happens. |
(Post 6283741)
Yeah, the phenolic spacer is a must. You're referring to a 80mm TVS pulley right?
Progress, there's more in there though... (blue line is m62 3.35" pulley, boost is so high in all of these pulls because of ~30.0X barometer) a few days ago, it was ~29.4 and boost was only 19.3 @ 7200rpm http://img29.imageshack.us/img29/5448/progressg.th.jpg |
http://i857.photobucket.com/albums/a...th4yearson.jpg
meth? pre-blower? I wouldnt. |
(Post 6283983)
(Post 6284154)
Wow, I never expected meth to do that. Guess I'm going witout meth.
(Post 6283983)
