Performance Mods: Adding TVS
So finally I got a TVS thanks to dcoll177, good guy and good deal. (Super fast shipping!!)
Anyway, so far I have a
1. TVS shown below: (redish color due to loctite seal)
100_1435.jpg picture by jgarciarivera - Photobucket
2. Stage 3 Exedy Clutch
100_1313.jpg picture by jgarciarivera - Photobucket
3. Boost gauge up to 30 psi
100_1317.jpg picture by jgarciarivera - Photobucket
4. 80 lbs injectors
100_1422.jpg picture by jgarciarivera - Photobucket
5. Plugs
100_1423.jpg picture by jgarciarivera - Photobucket
6. Injector harness
100_1424.jpg picture by jgarciarivera - Photobucket
7. Belt
100_1419.jpg picture by jgarciarivera - Photobucket
And my mods on my sig. Goal is 350-400WHP.
My first stage is: Reading Which means learning about mods, parts, equations, CFM etc. I downloaded the GM handbooks. Also, this stage includes planning, and budgeting. Please, bear with me, I'm an Electrical Engineer, so I don't have that much skill has the people on this site.
Second stage: Getting in shape my old 1986 toyota. Cobalt is my DD so I can't start mods until I have a backup car to drive to work. Someone suggested me once to put a 2JZ motor on it.
Also, I'm waiting for tax return so money is coming eventually.
Third Stage: Complete planning, budgeting. Which means, a complete list of parts, part numbers, vendors. Logistics: what to do first, that is, best route for mods economically speaking.
I will be slowly updating this thread, so feel free to add comments.
For each part you guys suggest, I will be putting a list of the parts and the name of the poster.
Power Race Parts suggestion- Do research
1. pecorillif - mid length to long tube header
2. Turbo Tech Racing (Vendor) - Upper Engine Mount and STOP Transmission Bushings
3. omnigear - Powell Rotated mounts
4. alleycat58 - ZZP header
5. sjc0013 - heat exchanger
6. rootbeer - phenolic spacer
7. rootbeer - 80 mm pulley
8. rootbeer - Griffin HE
9. jgarciarivera - ZZP 3" CAI
10. jgarciarivera - LS4 TB
11. zfissette - ZZP Stage 3 HE in series with radiator
CSS.net references
Exhaust
https://www.cobaltss.net/forums/2-0l...ing-lsj-66344/
https://www.cobaltss.net/forums/2-0l...lt-ss-sc-6872/
Engine stats
https://www.cobaltss.net/forums/gene...e-stats-26790/
Air management (CFM)
https://www.cobaltss.net/forums/2-0l...j-parts-67539/
Thanks all
Jose
4. 80 lbs injectors
5. Plugs
6. Injector harness
7. Belt
CSS.net references
Exhaust
Engine stats
Thanks all
Jose
That will be great! TTR for the win.
Last edited by jgarciarivera; Jan 18, 2012 at 08:33 PM. Reason: Automerged Doublepost
the real question is Aaron, is ita bushel on the cob or shelled? Lol a sad attempt at a joke I know, but Ive grown up on a farm and handled a bushel of corn in both those ways.
Shelled is ~56 lbs, why ship a cob, unless he wants to put one up someones @$$
What size pulley are you planning to run? If you don't have access to E85 you're going to need meth [EDIT: or some other way to add lots and lots of cooling] to be able to run enough timing to hit those numbers.
This is my car:
https://www.cobaltss.net/forums/dyno...5-dyno-246633/
Have since added a ZZP header, but did not re-dyno. Car needs some more work first. Bad coilpack makes it sad panda right now, but I have house mods to do first.
This is my car:
<dual pass, option b, long tube, K&N cone filter, bkr7e, 60's, tvs(80mm), 93...needs more timing in the low-mid range but so far making around 275hp 235tq
i need a phenolic spacer
This is my car:
This is my car:
About Meth, well, we'll see what happens.
