Performance/no Tune?
Old Jun 18, 2008 | 11:55 AM
Sanat's Avatar
Alright I had a question about what performance mods are safe before having to get a tune.? (i know i'll fully benefit from the tune but I'm just wondering)
Like if I get a 3" pulley, spark plugs, and 42lbers is that safe?
Just wonder'n what will be safe without a tune.
thanks guys.
Old Jun 18, 2008 | 12:05 PM
mike25's Avatar
no that will require a tune...you can sneek by with a full exhaust and maybe an intake before you need e tune, but thats pushing it
Old Jun 18, 2008 | 12:09 PM
LamboW9's Avatar
intake, exhaust, meth, spark plugs, h/e, better tires, lowering springs, suspension work<sway bars, tranny mounts and engine mounts, STS, i think thats about it
Old Jun 18, 2008 | 12:17 PM
mike25's Avatar
i didnt know you could do all of that without a tune...
Old Jun 18, 2008 | 12:21 PM
Sanat's Avatar
ah. so a drop to a 3" pulley isn't gonna happen without a tune lol.?
Old Jun 18, 2008 | 12:28 PM
LamboW9's Avatar
i've heard of ppl running a 3" pulley with stock injectors and a good set of properly gapped spark plugs but i wouldnt call it "safe" <<stage kits require tunes
most of that isnt performance...the meth you can be conservative but w/o a tune you won't see a real performance gain...you'll just see colder IAT2s...the full exhaust an CAI is ok to run w/o a tune definitely...you'll just throw a 0420 CEL that is because of the high-flow cat but when you get your tune done you can get that code deleted off your pcm so it won't bring on your CEL anymore
Old Jun 18, 2008 | 12:29 PM
rnjmur's Avatar
Exhaust and intake are fine without a tune. You can do a pulley swap without a tune, but the stock injectors probably won't fair good. If you swap out the injectors you HAVE to get a tune.
Of course like you said before, to get the full amount out of any mod you really need to get a tune for anything.
Old Jun 18, 2008 | 12:36 PM
Sanat's Avatar
nice. Yeah I wish I had some HP Tuners. =( so expensive...
Old Jun 18, 2008 | 02:20 PM
LopsidedJester's Avatar
hptuners, almost as expensive as a corsa touring exhaust
Old Jun 18, 2008 | 02:22 PM
Area47's Avatar
Rent me! per hour
being cheap about things is a very quick way of finding out how to rebuild an engine.
Old Jun 18, 2008 | 02:27 PM
Sanat's Avatar
lol. well put. I want hp tuners so much. I heard you learn soo much just from messing around with that. Well I guess I'm gonna invest in that.
Old Jun 18, 2008 | 02:34 PM
light'bolt's Avatar
get the pro version, you'll be happy you did. Dont forget the wideband too.
Old Jun 18, 2008 | 03:42 PM
Sanat's Avatar
Ight. Thanks for the help. I am going to install the 3" pulley and sparks, and get hp soon after.
Old Jun 18, 2008 | 03:50 PM
Hockeyman's Avatar
^enjoy rebuilding your engine then
Old Jun 19, 2008 | 08:22 AM
LamboW9's Avatar
i wrote nothing about a pulley....you will make your stock injectors go wayyy static....and static injectors are not good...pluse since they are static your leaning out your engine alot...put it this way....our stock injectors are 34lb stage 2 is 42lb injectors.....a 3.0 pulley and good tune with the 42lb injectors..they are pretty much max'd out...borderline from going static on that 3.0 pulley....IMAGINE what kind of stress your putting on your engine and injectors being that overly Static because you thought you were gaining hp...<<enjoy it while it lasts
stock injectors+ 3.0 pulley and no tune=SSSTTTTAAATTIICCCC ouch!!
42lb injectors+3.0 pulley and tune= max'd out <<with a 2.9 pulley you go static
QFT <<<
Old Jun 19, 2008 | 09:26 AM
rrutter81's Avatar
yea im pretty sure with stock pulley and injectors we have a 120-130 IDC @ 6500 RPM.
Best to not play with a smaller pulley.
Old Jun 19, 2008 | 09:31 AM
Werewolf SS's Avatar
I have logs to prove that statement.^^^
Stock Cobalt SS S/C is already maxing injectors.
Old Jun 23, 2008 | 12:16 AM
Sanat's Avatar
Hey Werewolf SS I'm in Florida, I'm thinking ima get 42lbers and tune. Can you tune?
btw, sorry for being noob guys, thanks for help
Old Jun 23, 2008 | 12:25 AM
CobaltSS 16's Avatar
CAI and full exhaust. Any other performance/engine parts I would get a tune.
Supercharged06SS
Dec 11, 2022 04:47 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
