Pic Request: 5th Injector
Old Aug 12, 2007 | 02:24 PM
Admiral Jedi's Avatar
Looking for some pictures of a 5th injector on a boosted setup. Specifically, the fuel lines involved and where it was mounted relative to the throttle body.
Also: Any ideas on preventing puddling in the manifold?
Old Aug 12, 2007 | 02:43 PM
SpecialK's Avatar
From what I've seen they put it just behind the TB in a spacer and it's set with a piggyback to inject fuel relative to boost pressure. THis of course is what Stillen does with the 350Z
Old Aug 13, 2007 | 06:34 AM
RaineMan's Avatar
Yeah... wait for a real tuning solution. Running fuel in the intake manifold just has bad idea written all over it.
Old Aug 13, 2007 | 12:04 PM
-Jayson-'s Avatar
he has tunning, hes got an ecotec cavalier. If your upset because you got the GM crap tune, go buy a stock PCM and use HPtuners to tune it for bigger injectors. A 5th injector is a bad idea. Its like putting a bandaid on a cut that needs stiches. Id almost guarantee a nice backfire from that gasoline then say buy bye to your 1,000 dollar supercharger.
Old Aug 13, 2007 | 02:35 PM
RaineMan's Avatar
Umm... just FYI... tuning for an Ecotec Cavalier is waaaaay different than tuning for a Base model Cobalt. Totally different ECU.
Old Aug 13, 2007 | 02:47 PM
-Jayson-'s Avatar
he wasnt asking about tuning, he was asking about placement of the injector and how to prevent puddling
Old Aug 17, 2007 | 06:21 PM
rlinden86's Avatar
isnt that like the piggy back for say a turbo or something.
ryan.
Old Aug 25, 2007 | 05:49 PM
fstcavy's Avatar
dont worry about a fith injector bro..im ay 15psi no need for extra fuel
Old Aug 27, 2007 | 09:05 AM
Sw4y1313's Avatar
Well the setup i HAD, theres a hat that goes over the TB that houses the 5th injector. Its setup so the air coming goes into a swirling effect and atomizes the air with the fuel. I had no problems with fuel puddling with that setup, but then again you have a SC. It wont work the same.
If your going to run extra injectors, run 4 extras, one in each runner. But i doubt thats possible with that intake manifold and the SC on top. Why would you consider a 5th injector, do you have issues with tuning?
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
