Pics Needed!
Pics Needed!
Does anyone have some pictures of the piston sprayers that are in the 2.0 block? I need to find some detailed pics so that i can deside if they can be made to fit the 2.2 block with some drilling and tapping.
Any help is greatly thanked!
page 3 gm sport compact build book " All Ecotec blocks are cast with passages for piston-cooling jets and an oil cooler for high-output turbocharged applications". I'm looking for part # for you in here too, give me a sec its a lengthy list of parts for LSJ and L61
now who has the part number for them
only thing I can find that sounds like it could be it is the following:
gm build book page 19 under LSJ parts list. I'm assuming this is it because these parts on not listed in the L61 section.
"Nozzle assembly-Piston oil": -----12791255
"Nozzle-Piston oil": ----------------12791256
"Bolt/Screw-Piston oil Nozzle"-----12791243
"Tube-Piston oil Nozzle" -----------12794255
not sure if this helps, but I tried
