Spike's build thread
#79
found a local place 2 tear down my trans. clean, micro polish,and cryo it....... all for a good price!!!
tear down and clean-$200
cryo-$130
micro polish-$250
cryo-$130
micro polish-$250
#82
im taking my trans up in a few weeks..... but my friend is doing the trans on the side. I can ask him when hes done with mine if he would be willing 2 do more.
#95
I was going to buy one of their new ones but there was a concern on weather it would fit or not behind the LSJ since they made it for the 2.4l ss which has more room behind it. Do you have it installed yet?
#98
well if i ever get my motor back in my hand we will find out....but i have looked alot at my girls 2.2 and pics of the 2.0 and 2.0 parts and everything looks 2 be kosher...my only concern is the firewall & the intermediate shaft...the fire wall needs alittle more than aprox. 7.5" 2 clear(from the head). so this should be more than fine. The turbo hangs aprox. 9" from the bottom of the flange(t3\t4 57trim) so it hangs down by the inter. shaft, but i dont think its as low as(looked but havent measured). But it also looks like even if it is down by the shaft that it hangs far enough away from the block 2 miss the shaft(meaning sits behind)......so thats the scoop hopefully i will have more soon
06blackg85ss have u thought about running the LS4 tb on your setup. I am planning on doing so but didnt know if there would be any bad side affects. I know its not needed 2 make the power i want but, i already have one and it never hurts 2 go with a little bigger tb....imo
#99
so I just read through this entire thread and man is it an inspiration to turbo mine LOL. wish i had the funds/time/and another car to drive. GL with your engine and test fitting the manifold. Looks great and keep up the good work!
#100
thank u sir... I will try....
im looking at getting these in the spring for my auto-x wheels.....http://www.racelinewheels.com/p-224-magnesium.aspx I called 2day....for a 17x7.5" 5x110 wheel they are $195....and yes they only weigh 9lbs...lol
