Timing Between Engines
Old Aug 20, 2012 | 11:43 AM
Axelthered05's Avatar
Ok so there have been a few threads about people wanting to pair various diferent blocks with diferent heads for example, LE5 Block+LSJ Head or L61 Block+LSJ Head or L61 Block+B207R Head and so on. my question that I have yet to see answered is how does the engine timing change from engine to engine or is it the same for all engines? if not hoe do you go about setting the timing?
Old Aug 20, 2012 | 05:47 PM
nobody has an answer for this?
Old Aug 20, 2012 | 10:02 PM
Sharkey's Avatar
are you refering to ignition timing or cam timing/cam phasing?
Old Aug 20, 2012 | 11:34 PM
timing chain alignment so i gess cam timing
Old Aug 24, 2012 | 05:09 AM
cavi2sunfire's Avatar
the L61 and LSJ use the same parts for the cam sprockets so timing those as a frankenstein is easy
Old Aug 24, 2012 | 10:57 AM
i see thanks for the info
GaryGibblez
Jan 14, 2020 10:35 AM
Cptnslo
Sep 24, 2015 09:32 AM
09BlkCrusader
Sep 9, 2015 04:47 PM
Adam144
Sep 3, 2015 07:48 PM
