Turbo Experts
Old Apr 5, 2009 | 03:36 AM
2MCHBoost's Avatar
Turbo Experts
Could you provide a comprehensive list of comparable budget turbo's that are comparable to Garrett's line? Comparable turbo's to a GT28R, GT30R, and a GT35R.
I'm looking on building a budget setup and am looking for 350whp with great spool on or around 20psi of boost. This turbo will be going on a built 2.4L and not an LSJ.
Old Apr 6, 2009 | 09:57 AM
celicacobalt's Avatar
check out zzp, maybe they can work something out for you on a budget.
Old Apr 6, 2009 | 10:01 AM
06black's Avatar
why would you not do this yourself?
start matching up compressor maps, flow Vs PR.
any who, whats your "budget" per say?
I'll match them to my beloved prescion units, but there not cheap.
Old Apr 6, 2009 | 10:10 AM
2MCHBoost's Avatar
I wanted something in the 600-700 dollar range but i've settled on a GT3071R
Old Apr 6, 2009 | 10:28 AM
06black's Avatar
with a 2.4, that'd be stuped.
the turbine is to small for that that CI.
if you just want a real quick street terror, I'd lean toward a 2876.
look at the turbine graph (not compressor map) for the 71mm turbine Vs 76mm.
http://www.turbobygarrett.com/turbob...R_705330_2.htm
Old Apr 7, 2009 | 09:01 AM
Turbo06Sedan's Avatar
Higher the number in the turbo name, doesnt necessarily mean faster.
The GT28RS will handle 350whp at 20psi...and since im at about 300whp at 10psi. I doubt i'll have to go up 10 more psi to hit 50whp. Not to mention, anything over 15psi you run the risk of blowing your intake mani.
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
