turbo question
Old Jan 28, 2007 | 11:19 PM
shiftingloco310's Avatar
turbo question
ok say i found a 2003+ saab 93 2.0t in a junkyard....if i took the intake manifold and turbo manifold what else would i need to make the turbo work in the ss/sc?( besides dp, tuning, and turbo,fmic) and im not talking bout twin charging just going all turbo.
Old Jan 28, 2007 | 11:23 PM
Rage915's Avatar
ive been wondering the same thing
Old Jan 29, 2007 | 12:08 AM
rally's Avatar
you'd need a turbo
Old Jan 29, 2007 | 12:13 AM
TurboBlackBalt's Avatar
Depending on turbo, oil and water lines, external wastegate, intercooler plumbing, intercooler, full exhaust, and eventually, lower compression pistons (8.5 mayb 9:1).
The saab intake and exhaust manifolds bolt right up.
Old Jan 29, 2007 | 12:17 AM
Cobalt_Supercharged's Avatar
A recirc/BOV, tuning, oil lines, piping, and waste gate (if not built into the turbo). Not really sure what else. You could always wait and see what Tag includes in their turbo swap. You gotta make sure that the Saab manifold has a spot for all the sensors that go on the stock manifold and S/C.
Old Jan 29, 2007 | 12:52 AM
the intake manifold thing is true...as for turbo you can use one off an evo...td04..they use the same flange...idk im just trying to get input and ideas for the future...i mean once you get all the stuff say from a junkyard it prolly wont be too expensive...it'll be one of those budget turbo kits
Old Feb 17, 2007 | 09:07 PM
pjk91's Avatar
and the 2.4? it would work with that too i'm assuming?
Old Feb 19, 2007 | 04:41 AM
bdwarr6's Avatar
the saab motor is the exact same, it will bolt right up. Dunno if they put an odd ball engine in my car or does everyones say saab on the coolant bar across the back of it?
I looked into this and found it to be to small for my use, ive got a custom header being made should be done this spring/summer its free so me not bitching
Old Feb 19, 2007 | 05:01 AM
NJHK's Avatar
Wow, I can't believe I missed this thread...
Ok, here is the facts...
Fact # 1: The saab 9-3 uses a Mitsubishi TD04 Turbocharger
Fact # 2: The saab 9-3 uses a triangular style flange
Fact # 3: The saab 9-3 TD04 Turbocharger is internally wastegated
With this said, if you're thinking of using that manifold the way it comes and putting a typically T3 style turbocharger on it, you'll be sadly mistaken when you see that they are totally different and won't work at all.
Now, you COULD have the manifold modified and made a T3 flange but if you don't have connections like that, you might as well buy a new one (atleast in my opinion). Think about it, would you like a fresh manifold or hacked up one?
As far as keeping that TD04 turbocharger, understand that it is a smaller turbocharger and probably isn't going to push the amount of power you're planning for in mind EFFICIENTLY. Also, the internal wastegate is designed to open for a maximum maintained pressure of 10 PSi of boost pressure. Increasing the delay of wastegate actuator signal (hence what they do with boost controllers) on this type of setup could result in efficiencies if you're aiming for too high of boost pressure and also boost creeping.
About the intake manifold, I don't know too much about your stock throttle body but you would need a manifold that your throttle body can fit onto properly. Whether that one will do it, I don't know for sure.
Now, to be completely honest, I at one point was thinking of doing this swap on my sunfire. Why? Cheaper. Did I do it? No. Why? Because I realized I am using stock parts...which people are trying to get away from, stock, and I am going to it? lol
I also realized that ultimately, these parts wouldn't be as reliable or as efficient as I was looking for.
This is my take on it atleast...take it for what it's worth.
Old Feb 19, 2007 | 08:32 PM
pjk91's Avatar
cool. thanksman.
Old Feb 19, 2007 | 08:54 PM
Doc's Avatar
Doc
The 1st Gen Mitsubishi's used them right?
I know the Subaru's use this turbo also (TD04). They have options to upgrade to. Could we them as well..?
These are the ones my buddy told me about a long time ago.
TDO4-9B-6CM2 265 CFM
TDO4-13G-5CM2 360 CFM
TEO4-13C-6CM2 360 CFM
TDO4L-13G-6CM2 360 CFM
TDO4L-15C-8.5CM2 390 CFM
would this one work..GT3076R..?
Old Feb 19, 2007 | 11:01 PM
NJHK's Avatar
I honestly can't remember which version it is.
I'm sure there are upgrades but not as many as the oh so popular T3 style flanged turbochargers.
But the whole point is, why use a stock manifold? Know what I mean? If you're going all out and you're going for a quality setup, why retrospect your setup? I say spend the quality money for a quality manifold...and also you a manifold that you'd more than likely want externally wastegated (which you would have to end up having an extension made on the manifold...meaning more hacking).
Old Feb 19, 2007 | 11:07 PM
zinner's Avatar
Moderator Alumni
What about the 2.3 Saab turbo, thats runs more boost and HP, correct?
Old Feb 19, 2007 | 11:11 PM
Boosted_SS's Avatar
sorry to get off topic but i thought you were selling your buggy? how's it running? when are we gonna see videos/sound clips of the bad as new motor?
NJHK's Avatar
Ok...you're now barking up the wrong tree lol
I don't know TOO much about Saabs...my Saab research basically was exclusive the ECOTEC 2.0 Turbo (2003+) models. Sorry.
Old Feb 19, 2007 | 11:51 PM
zinner's Avatar
Moderator Alumni
I looked a bit more and the 2.3 is an saab exclusive engine and doesn't share anything with the 2.0 ecotec in the 9-3s. At least doesn't share anything I can find, so chances are a 2.3 turbo setup won't come close to working as a swap.
Old Feb 19, 2007 | 11:53 PM
NJHK's Avatar
I figured that...
Freakin ******.
Old Feb 20, 2007 | 07:13 AM
Doc's Avatar
Doc
It makes sense to use a custom built turbo manifold. Although, having a piece that bolts in place can be advantageous for those without access to someone who will build a turbo manifold for them.
Old Feb 20, 2007 | 07:27 AM
NJHK's Avatar
you mean to convert it from triangular to the rectangular style?
Old Feb 20, 2007 | 07:32 AM
Doc's Avatar
Doc
any of the above
yes
Old Feb 20, 2007 | 12:01 PM
NJHK's Avatar
any of the above
yes
I've never heard of such thing but I guess it wouldn't be impossible to make...
but, I would also think about how much space it's taking away behind the engine (on top of having the turbocharger there).
Supercharged06SS
Dec 11, 2022 04:47 PM
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
