what pistons
Old Feb 11, 2008 | 09:06 AM
ifknrock09's Avatar
what pistons
just curious as to what pistons people are running. aftermarket of course. i have been going back and forth on whether or not to put 10.5:1 in my car. just wondering if anyone has had luck or if people like these or hate these.
Old Feb 11, 2008 | 09:08 AM
Witt's Avatar
I use 10:1 Diamonds stock bore size with stock rings. I went up half a point in compression to make up for the loss caused by my cams.
Old Feb 11, 2008 | 12:29 PM
TurboTechRacing's Avatar
Diamond, we carry them @ www.TurboTechRacing.com
Old Feb 11, 2008 | 02:02 PM
ifknrock09's Avatar
i know that you guys carry them. i already have the 10.5:1 pistons i just don't know if i want to put them on. i would rather go with 9.5:1 or lower if possible.
Old Feb 11, 2008 | 02:07 PM
Coblt ss super's Avatar
you go lower if you go turbo or tvs right mainly running more boost and power
Old Feb 11, 2008 | 02:08 PM
1stbluSS's Avatar
The Detroit Pistons are currently my choice
Old Feb 11, 2008 | 02:41 PM
ifknrock09's Avatar
well the lower you go the better chance you have for predet. but alot of turbo guys go with higher compression. i think.
Old Feb 11, 2008 | 02:45 PM
NJHK's Avatar
You're thinking backwards.
Higher compression causes higher heat temperatures because the air/fuel mixture is tighter and causes higher combustion chamber tempatures which MAY lead to pre-ignition happening.
Now, you can run a high compression if you want and be absolutely fine. There are many ways of preventing detonation/pre-ignition. Read this: http://www.ecotecforum.com/forums/showthread.php?t=4539
Read # 4 on that page specifically.
Old Feb 11, 2008 | 02:46 PM
Omega_5's Avatar
Other way around....
Old Feb 11, 2008 | 03:04 PM
ifknrock09's Avatar
thanks guys. my only thing is is that i don't want to mess **** up i guess. whatever is the safest. safe as in for the motor. i have been thinking about meth injection for a while. plus there is a sunoco about 15 minutes away. they have the highest octane around "94". what is your take on E85? its about 100 octane. i know there are people using it as a cheap substitute for higher octane. its about 2.35 a gallon here in indy. i also know that you will burn about 25% more of it than if you were just running 93 octane.
Old Feb 11, 2008 | 03:10 PM
widebody_balt_ss's Avatar
I am not a fan of e85. I know others like it.
Old Feb 11, 2008 | 03:24 PM
Omega_5's Avatar
... sure it's 100 octane... but it has less energy value per unit volume.
Not worth it at all.
Old Feb 11, 2008 | 04:02 PM
ifknrock09's Avatar
so would meth. injection be the way to go? thats what i am leaning towards. that and getting retuned.
Old Feb 11, 2008 | 04:06 PM
LopsidedJester's Avatar
if your cars not made for flex fuel or E85 i highly discourage use as a "cheap" 100 octane. E85 as any alcohol has corrosive properties that can be harmful to most of your fuel components. Also, like omega said it has less energy per volume so your performance would suffer.
Old Feb 11, 2008 | 04:37 PM
ifknrock09's Avatar
right right. i think that i am just gonna find some 10:1 or 9.5:1 pistons just cause. and just run a meth injection kit.
Old Feb 13, 2008 | 04:03 AM
2K5SS/SC?'s Avatar
I'd go with 9.5:1 compression if I were you. It all real depends on if you're going all out though. Are you going to do headwork or anything else?
Old Feb 13, 2008 | 07:26 AM
ifknrock09's Avatar
yeah i have a head at a machine shop right now. 9.5:1 is what i am gonna go with. just not for a while.
Old Feb 13, 2008 | 12:56 PM
AddictsRacing's Avatar
9.5 is great,best of both worlds,not to high not to low. Turbo plans in the future?
Turbo Johnny
Feb 21, 2019 09:41 AM
hhrfreek
Jun 4, 2016 11:25 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
