Alcohol Injection Systems Alcohol Injection Systems is a Supporting Vendor
AIS Meth Injection GB
Old May 31, 2008 | 12:05 PM
  #51
quadracer0387's Avatar
just dont hook it up yet... this is a good deal you will be missing out on
Old May 31, 2008 | 12:06 PM
  #52
SJSchafer's Avatar
Originally Posted by Billig ss/sc
That's what everyone's been saying, but idk. I'm gonna wait for someone I know around here to get it first so they can help me out with it. How long/far can you drive untuned? 'Cause whenever I put it on I'll have about an hour drive to the place that's going to be tuning it.
You can drive as far as you want, just stay out of boost. Even if you do go into boost to the point where you spray, you'll just go rich. That's not a great thing, but better than going lean.
Old May 31, 2008 | 12:11 PM
  #53
Billig ss/sc's Avatar
Sorry for all the noob-age guys, but what's the difference b/n Stage 1 and Stage 2? And does either one come with a tank so I dont have to use my washer fluid reservoir?
Old May 31, 2008 | 12:27 PM
  #54
Cyclone's Avatar
Still cant figure out if this is ok with the stage 2 tune?
Old May 31, 2008 | 12:28 PM
  #55
most positive you will need to be tuned
Old May 31, 2008 | 12:42 PM
  #56
SSSCEnthusiast's Avatar
Everyone here says " noticeable gain" but I REALLY beg to differ. It works, that's for sure.. my IAT's are ridiculously low with the meth and Heat Exchanger, but as far as power, i really didnt feel anything.
Old May 31, 2008 | 12:49 PM
  #57
SJSchafer's Avatar
Really? I was able to completely redo my PE and add a bunch of timing. 3rd gear pulls like 2nd used to.
Old May 31, 2008 | 12:55 PM
  #58
Difference between the Stage 1 and Stage 2 kit?
Old May 31, 2008 | 01:02 PM
  #59
SJSchafer's Avatar
Stage 2 is progressive, so that you can adjust the flow from the point where it starts flowing to the point where it is fully sprating. Stage 1 is on or off - no progressive.
Old May 31, 2008 | 01:04 PM
  #60
So you just set Stage 1 to kick in at like 10psi or something and it just goes? Whereas Stage 2 you can adjust it so it eases into fully spraying?
Old May 31, 2008 | 01:05 PM
  #61
I think maybe AIS sent me a nozzle that's too small for my application... I used -20*F washer fluid, and couldn't even advance a half degree.
  #62
cooljake73's Avatar
stage 1 trunk mount right here
Old May 31, 2008 | 01:10 PM
  #63
Is there any advantage to trunk mount vs firewall mount or is it just where they're mounted
Old May 31, 2008 | 01:17 PM
  #64
Just mounting position, once the lines are primed with fluid it's going to get to the nozzle in the same amount of time.
Old May 31, 2008 | 01:24 PM
  #65
Okay that's what I figured. Does Stage 1 or Stage 2 come with a tank?
Old May 31, 2008 | 01:25 PM
  #66
I believe both do, but just FYI, you can get stage 1 fender mount with no tank and you can tap your windshield washer fluid tank. It's space effective and works just as well.. it's what I did
Old May 31, 2008 | 01:29 PM
  #67
That's what I thought about doing, but wont you lose your washer fluid? I'm in NJ and the bugs here are f'ing insane so I kinda need it haha
Old May 31, 2008 | 01:30 PM
  #68
No sir, why would you lose your washer fluid? I can get some pics in a few if you'd like!
Old May 31, 2008 | 01:32 PM
  #69
I'm a meth noob, you'll have to excuse me lol. I swear I'm good with most everything else haha
And yes
Old May 31, 2008 | 01:54 PM
  #70
Okay, so, here's Methanol Injection for Dumbies.
The Methanol, in my system, Comes through this small line tapped into the windshield washer reservoir.
It then travels through this pump.
Through this check valve
and straight into this nozzle.
Other than the wiring, the only other thing you have to do is tee off a vacuum source, so the pump will come on at X amount of boost.
Hope that helped
Old May 31, 2008 | 02:03 PM
  #71
Yea that cleared things up a bit. Just gotta find someone around here to help me put it on when I get it that knows what they're doing haha
Old May 31, 2008 | 02:08 PM
  #72
It's reallly reallllly not hard. If you can put on a CAI you should be able to put on methanol, IMO.
Old May 31, 2008 | 02:13 PM
  #73
Okay cool, I did the CAI in like a half so that makes me feel better haha
Old May 31, 2008 | 02:23 PM
  #74
Haha, like I sad... it's really simple, people hype it and make it seem harder, I believe.
Old Jun 1, 2008 | 09:54 AM
  #75
Joeyavhu's Avatar
Okay, so I will be calling on Monday to place the order. Stage 1 should be good for me.
