All New AIS Competition Rear Trunk Mount Water Methanol Injection Systems
Non Authorized / Non-Supporting
Competition 3 tanks are in stock now and ready to ship.
Features & Benefits Include:
*Top of the line billet mold for exact tolerances and perfect straight lines you can only get from a billet mold.
*Black shiny textured finish. Easy to clean and looks great no matter how old the tank is. No more white tanks with dirty greasy finger prints or marks on it that won't come out. Just wipe it down with armor all and the tank really shines.
*Aircraft style flush mount cap with stainless hardware. This cap assembly is very expensive and cost us a lot! We could have easily cut corners and used a cheaper plastic cap as our competitors but it wouldn't have offered the value, features or looks of this cap.
*Aircraft style cap allows the use of inserting safety foam inside the tank for the ultimate in fluid control during road racing and street use.
*Large 3/8" NPT fittings molded into the tank. We could have easily not spent the extra money it costs to engineered our mold with this feature and simply just drilled and screwed fittings right into the plastic tank as our competitors. But this would have been cutting corners again and given someone else the opportunity to out do us and make it better.
*Dual 3/8" NPT fittings allows the use of 1/2" pick up hose. Allowing our pump to out perform any competitors pump using the smaller restrictive 1/4" hose. Essential for our 1200+ horsepower customers who need every bit of their pump.
*Dual 3/8" NPT fittings also allows our tank to be used as a trunk mount 3 gallon reservoir for air to water superchargers. Not just a water methanol tank. Simply remove the plug and you can now run both feed and return lines.
*Dual 3/8" NPT fittings allow the use of a second pump for our extreme applications which require the use of two pumps. Sounds crazy but it happens.
*Custom bent aluminum mounting straps to fit the tank perfectly. Each strap is also machined for a nice brushed look. We could have just bent the straps and called it done but we didn't.
*First trunk mount tank with built in virtual sump with rear pick ups.
*3 Gallons capacity vs competitors 2.5 gallon
*Pump reversed under the tank for a clean, stealth appearance above. First and only of it's kind.
small companies that give a damn will......
http://www.alcoholinjectionsystems.c...duct_info.html
Rodney
Rodney got my Stage 2 kit today and I'm a bit confused/disappointed.
Order #468
Kit is missing:
- Built in serial port for connecting laptop
- Free Windows based software available
- System includes a serial port for connecting to a laptop
and
- Interchangeable injectors sized to application
- Stage 2 installation instructions (packaged with Stage 1 instead)
- Low level sensor installation instructions
Please lmk what's going on.
Thanks
Order #468
Kit is missing:
and
Thanks
Order #468
Kit is missing:
and
Thanks
Order #468
Kit is missing:
and
Thanks
Rodney
Nice talking with you. Let me know if you have any other questions. Feel free to email me at rodney@alcoholinjectionsystems.com or by phone at 801.447.2559.
Rodney
Rodney
I've emailed you a few times, called and left a message and still haven't received a response from you and it's been about a week and a half.
I still need the wiring instructions for the low level sensor.
Rodney
Recieved my kit today. VERY high quality. Appears to be a straightforward and relatively simple installation.
My only concern is wiring up the low level sensor. Rodney, do you have any instructions that you can e-mail?
Rodney
thanks Rodney! Product was packaged really well btw
