3rd accessory outlet
Old Mar 4, 2011 | 08:23 PM
deereboy4320's Avatar
would it be possible to install another outlet next to the one under the radio? would i need to change the fuse amp size. i already have a pa system hard wired into the outlet already.
Old Mar 5, 2011 | 10:05 AM
dillw33d's Avatar
safest bet would probably to be sourcing power from the fuse panel without tapping from another outlet. the wires are fairly small gauge iirc, and might not like the extra current too well. or to wire your PA system into another circuit.
Old Mar 5, 2011 | 10:16 AM
ecot3c inside's Avatar
uhh get the dual outlet plug so you can plug another thing in?? why would you "install" anything?
Old Mar 5, 2011 | 06:21 PM
that is a good idea. for the dual outlet, there is now room for those beefy things. the more it looks like it should be there the better
Old Mar 5, 2011 | 07:50 PM
Nighthawk243's Avatar
As long as you wire it up properly, yes.
Old Mar 5, 2011 | 08:54 PM
Well what do you consider properly
Old Mar 5, 2011 | 09:00 PM
smitzk01's Avatar
well if you have any unused slots in the fuse panel you could wire a free standing fuse for the pa system. just figure out what amp of a fuse would be safe and use the correct size wires. I did this when I put my interior lights in on my Rx7. I just used an empty slot in the fuse panel to bring power out and to make sure if anything shorted it wouldn't fry anything else, and then I grounded it via chassis.
My question would be how much current does your pa draw?
Old Mar 6, 2011 | 02:53 AM
Not much since it is hardwired into the outlet under the radio. That fuse is only 15 amps so it cant be much. I use that outlet for my radar so there isn't much at all
Old Mar 6, 2011 | 07:45 AM
smitzk01's Avatar
You could always add another 15 into the fuse box.
Old Mar 7, 2011 | 02:53 PM
thats probably what i will do
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Fearedbynone
Apr 14, 2016 03:25 AM
grampss
Sep 27, 2015 08:51 PM
The Rookie24
Sep 20, 2015 04:33 PM
