4th gen projector issue
Old Feb 19, 2010 | 11:10 PM
_UnLiMiTeD_'s Avatar
Just got my 4th gens in, put them on and within an hour, both were fogging up right on the inside corners. How can both not be sealed? The difference i noticed between these lights and the stockers is the cap that covers where the bulbs go in is made of flimsy rubber you just push on where as the stockers screwed in with hard plastic ones.
Could that be where the moisture is getting in?
Old Feb 19, 2010 | 11:14 PM
Southtown57's Avatar
You are the first person that I've heard of having problems with these. But then again not too many people own these yet. Maybe you just got a bad set? If your still in the return period send them back for another pair. The rubber fitting your describing could be the cause. This is why I'm not sold on ebay lights though.
EcoTecDriver's Avatar
defective?
Old Feb 19, 2010 | 11:18 PM
another person in one of the 4th gen threads made the same complaint, fogged up after 1 night, im going to be ****** chocked if i need to send them back, shipping to canada takes forever
the lights are made by depo, a huge manufacucture for OEM lights, just distributed from different ebay vendors
Last edited by _UnLiMiTeD_; Feb 19, 2010 at 11:18 PM. Reason: Automerged Doublepost
Old Feb 19, 2010 | 11:27 PM
Cobalt08LS's Avatar
make sure both grommets are on right. i tryed to just make a slit on the bottom to feed my hid wires because i didnt make a hole in the center on the driver light when i first installed them. it came undone in the car wash and it fogged a inch pm the bottom of the light on the driver side because i made that slit as the passanger had the hole in the center.. so i took the grommet as i like to call them from my gen 1 projectors and put a hole in the center for the hid wires and fed the wires thru and put it back on and made sure they were on correct and since then i have have no fogging.
check to make sure the grommets are fully on dude.
hope this helps
Old Feb 19, 2010 | 11:46 PM
Im going to go out tomorow and check, hopefully its a simple fix. The company emailed me back saying to make sure the breather tubes arent blocked
Old Feb 19, 2010 | 11:47 PM
DevSS's Avatar
Mine both fogged up too, I was choked but after a couple days i looked again and it was fine... It's been three weeks same weather and no fogging!
Old Feb 19, 2010 | 11:55 PM
Well i'll give them a few days and if it goes away great, i hope to god they do, i really dont want to ship them back to the states, takes weeks
Old Feb 20, 2010 | 12:03 AM
TurboSS's Avatar
ya I reported the problem to depo. They are really cool about helping us fix this. I live in Minnestoa and has been 35+ - 12+ out side and my fogging comes and goes. I think I might plug the bottom tube tonight and see if that makes a diff or not.
Old Feb 20, 2010 | 01:06 AM
im hoping this goes away
Old Feb 20, 2010 | 01:08 AM
Crazypolak00's Avatar
I had a little bit of fogging one night, but nothing ever since. I dont know if it was a freak thing but I have kept my eye on it and nothing in weeks now..
Old Feb 20, 2010 | 01:13 AM
CordiaDOHC's Avatar
Well im waiting to hear what goes on with this because I was going to order a set on the 3rd.
Old Feb 20, 2010 | 01:19 AM
first email i got back was they have sold hundreds without a single issue, but said if it cant be resolved they will gladly send me a new set
Old Feb 20, 2010 | 07:49 PM
2008G5GT's Avatar
If it's cold out, lights are gonna fog up.
Should go away with headlight use and time.
The air inside the light had to equalize with the outside air. Think about this, they've been in a warehouse/box for weeks, the air inside is going to be warm. Outside is cold, fog happens.
Wait a couple days and you should be fine.
Old Feb 20, 2010 | 09:25 PM
ViSiONZ's Avatar
Same thing happened with my old 2nd gens. I took off the rubber caps & used a hair dryer to blow hot air in to the light housing. It seemed to fix the problem pretty well. After time though they stop fogging up. You just have to be patient.
Old Feb 21, 2010 | 03:24 AM
well so far so good, was gone by early afternoon, little but of fog when i washed the car but it went away within 20 minutes and hasnt fogged up so far. Love these projectors, much better then stock reflector housing, see much further
Old Feb 21, 2010 | 04:06 PM
Cobalt08LS's Avatar
thats what i hated with my gen 1s
they fogged up but it went away
luckly i dont have this problem with the gen 4's
Old Feb 22, 2010 | 09:01 PM
well one light has like heat crackin on the inside so im getting them exchanged anyways.
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
jrocstar
Sep 26, 2015 11:42 PM
