stock dp? and you put the wideband in an 02 bung on the dowpipe if you have one thats not being used..but if youre getting tuned you can have the rear 02 sensor code deleted and can put the wideband in that bung
ok but where can i place the gauge i got no spots in my triple pillar pod, and also, do i need anythign besides 2.9 and injectors
u can have it chillen in the small compartment on the driver's side to the left " i would recommend that you put it on the pillar and take one of the unneccesary ones out " , if your tuner is going to utilize that, you would have to make sure that ur tuner will have access to the analog wire coming out of the wideband, certain tuners will ask you to buy a a connector plug and hook it up to the analog wire of the wideband so all they would have to do is plug theirs into urs and they're up and running
