anyone know how
Old Dec 25, 2010 | 12:33 PM
DEZZIE41's Avatar
anyone know how
so i got my triple gauge pod filled, and my thing now is how and where can i put my wideband airfuel so i can get my tune
Old Dec 25, 2010 | 12:36 PM
blk06cbltss's Avatar
stock dp? and you put the wideband in an 02 bung on the dowpipe if you have one thats not being used..but if youre getting tuned you can have the rear 02 sensor code deleted and can put the wideband in that bung
Old Dec 25, 2010 | 12:38 PM
DEZZIE41's Avatar
ok but where can i place the gauge i got no spots in my triple pillar pod, and also, do i need anythign besides 2.9 and injectors
Old Dec 25, 2010 | 12:42 PM
SunburstSS's Avatar
u can have it chillen in the small compartment on the driver's side to the left " i would recommend that you put it on the pillar and take one of the unneccesary ones out " , if your tuner is going to utilize that, you would have to make sure that ur tuner will have access to the analog wire coming out of the wideband, certain tuners will ask you to buy a a connector plug and hook it up to the analog wire of the wideband so all they would have to do is plug theirs into urs and they're up and running
Old Dec 25, 2010 | 12:44 PM
DEZZIE41's Avatar
would i be able to use a intecptor for my wideband? or do i actually need a wideband in general
Old Dec 25, 2010 | 12:46 PM
Sizzle06's Avatar
You would have to get kit for your interceptor to make it work as a wideband.
Old Dec 25, 2010 | 12:48 PM
iterceptor works just fine. and yes you also need a smaller belt, tune, and plugs gapped
