ARGH! resistor help!
Ok here's the deal, I decided to install my LED tails today, ordered 6 ohm resistors as recommended and installed one onto the drivers side (if you were standing behind the car). I spliced the wire, installed quick releases onto the resistor ends and car wire. Unfortunately after doing this, I still had the hyper flash. tried the other wire (even though my multimeter read a current only on the yellow) and nothing. Is it possible that there is a way to put these resistors in backwards (though they aren't labeled as right and wrong ends) or do I have to splice this resistor into the ground (though that doesnt make any sense) or could it just be a bad resistor? I'm sort of a noob at electrical and I ended up getting fed up, removed the resistor since it wasn't doing S#!t anyways and called it a day. Oh and by the way, our headlights suck and non user friendly when it comes to changing a simple bulb too... Any suggestions would be greatly appreciated!
