Before Stock Springs/After CM Springs
UPDATE! Found the problems with my car about vibrations when you go higher RPM. I looked my car and asked few mechanics and they told me to check drive shaft on my car. I did checked and found that my drive shaft bolts was alittle lose due to drop the car alittle. So, I had to retighten my drive shaft alittle. So far I have NO vibrations at all when you go higher RPM. If any guys dropping you car make sure any of you guys dropping your car check your drive shaft and retighten them then you're good to go.
the axel nut shouldnt be loose after lowering the car... thats from something else. lol, and you dont have to worry about axel bind on CM springs.... my camber wasnt out when i get my alignment done, but every car is different.
trust me, it wasnt loose from lowering it, if that were the case every time you went through a dip on the road and the suspension compressed the nut would loosen. someone just didnt tighten it on your car. its torqued to like 190 ft pounds, that thing isnt going anywhere unless its screwed with.
