Blacking Out My Headlights!
Old Jun 3, 2011 | 12:06 PM
daniyelru13's Avatar
Alright, so I finally found some time to do this.
I'm really excited to see the finished product!
The steps that I'm following are:
1. Take all three screws out of the rear of the light, and take out the bulbs and wires
2. Put headlights in oven at 215* for roughly 7-10 min
3. pry apart lenses with a flat tool (I used a 1.5" wide putty knife, needs to be pretty stiff though)
4. reheat as necessary until lights are apart
5. Mask off parts of the light you don't want to paint (use blue painters tape)
6. Take either sandpaper or whatever you want to use and rough and scratch up the entire chrome bezel (NOT the reflector bowl) make sure you hit everything
7. Spray primer, get a few coats on there, and make sure you hit everything, the paint will only stick to the primer, it adheres very poorly to the chrome, let it dry between coats
8. apply color, make sure you let the paint dry between coats, does not need to fully cure. Don't go too heavy on the paint or it will run.
9. Once your happy with the paint, put the bezel back on with the screws, then put some new sealer on the lens to make sure it seals well. Use either the black silicone sealant, or you should use this
OCI Butyl Rubber Glue - Accessories from The Retrofit Source Inc
Easy to work with, and doesn't produce gasses when it sets
10. Press the lens onto the headlight firmly. Place into over at 215 again, let the adhesive all warm up, then press the lens on very firmly until all the clips are in position again, and use something like a ratchet strap to hold lens on till it completely cools, preferably overnight.
Old Jun 3, 2011 | 12:30 PM
Sweetsandman's Avatar
Don't put the lens back on until the paint's dry
Old Jun 3, 2011 | 12:31 PM
BumbleBee's Avatar
I only did like 175 degrees and watched them in the oven.
Old Jun 3, 2011 | 12:36 PM
anyone know of any "How-to's" with pictures??
Old Jun 3, 2011 | 12:50 PM
^^Like this one?
https://www.cobaltss.net/forums/sear...6&pp=20&page=2
Old Jun 3, 2011 | 05:13 PM
ALLLL DONE!!!
Before
After
Old Jun 4, 2011 | 12:04 AM
RyanJM's Avatar
Looks good nice job.
Old Jun 6, 2011 | 10:31 AM
Kbbalt's Avatar
Thats sick, its not much either like perfect
Old Jul 24, 2011 | 12:00 AM
Josh171's Avatar
hey, i know this is an older thread but was wondering how this effected the light output
Old Jul 24, 2011 | 12:02 AM
keiserX13's Avatar
dont see how it would effect the light output
Old Jul 24, 2011 | 01:22 AM
Josh171's Avatar
sweet thanks
Old Jul 24, 2011 | 01:59 AM
BlackARCA06's Avatar
Yup, doesn't affect it at all.
Old Jul 24, 2011 | 02:03 AM
livingdeadpk's Avatar
nice job
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
