Blacking out Tailights
Before i get yelled at for starting this up again....im looking to see everyones preferences over tinting the tailights like with window tint type material or the nightside...whats the pros and cons of each and what has the better overall effect....Thanks guys...i think this will be a good thread just to sum everything up
i did that niteshades, the only thing i dont like is that it is a flat finish and hard to make glossy again even with clear. But you can tint to the darkness you want and can alter with sanding. Easy to remove with paint thinner. my .02
CAsol pretty much summed it up. i too like how you can decide how dark you want the lights to be. i feel like i have more control when i use niteshades, but then again im sure its easier to mess it up
I used Nightshades on my last 'balt, and it works amazingly well. You can make it as dark or as light as you want and you can also do designs on your lights as well. (i.e. put a decal down before you paint, take it off when you're done and VOILA! instant originality) Definitely get a can of clear if you go the Nightshades route since the 'shade isn't glossy. (as CAsol stated)
I used that window tint on my tails and I love them (5%). However I did get a little heat dent in my third brake light... but im not even 100% sure thats what it is bc my friends used the film too and havent had a prob but heres mine...
Call Me Ghetto But I Did It With Regular Spray Can Black 2 Shades I Try Nightshade Dint Like The Result... Tint Look Better Bust Cost More I ALSO CHANGE THE REVERSE LIGHT I DID THE CENTER CLEAR SINCE I TOOK THE PICTURE BEFORE I DID IT .... I COULD NOT SEE **** WITH OUT THE CLEAR CENTER
HERE
HERE
Last edited by williamhvx1; Oct 19, 2007 at 04:22 PM. Reason: Automerged Doublepost
