Boredom leads to this..
lmfao. If you were in FL i'd do it no prob. Everyone always comments on how clean all my paint jobs that I do come out. But i cant lie, the rims were my first type of paint job on anything, and they came out greatttt. lol no drips, nothing.
Appreciate it brothaaa.
Last edited by murphxrockstar; Dec 12, 2010 at 12:50 PM. Reason: Automerged Doublepost
Here's the steps:
1)Take panels out.
2)Sand them down using 400 grit.
3)Clean with soap & water
4)Light coat of primer & let dry
5)Another coat of primer, slightly heavier. let dry
6)then light coat of red paint, let dry
7)again, another coat of red, slightly heavier. let dry
8)then couple coats of clear.
Now I read elsewhere that you can also sand it again after it all dries for 24 hours with like 1000 grit. Then you can compound & wax it to get the best shine. I'll probably do this today.
Thank you. Will probably wetsand & wax it today. It's already clear coated.
I think I might just leave it tan, I think it looks pretty good with the mix. Maybe i'm different, lol.
1)Take panels out.
Here's the steps:
1)Take panels out.
1)Take panels out.
As far as your wetsanding and buffing.. while 1000 isnt necessarily wrong.. you might want to start with a 1500 or higher grit.. will make your compound/polish steps a lot easier
There is a slightly easier way to paint them with a few less steps. If you are going to do the primer thing.. most primers need to be sanded or scuffed with 600grit sandpaper before the topcoat or color coat to ensure proper adhesion. You can also skip the primer step all together and scuff the panel with 600, mist on a very light coat of adhesion promoter, wait 5-10 minutes, then go at it with your color and clear.
brickloaf
Aug 30, 2015 08:59 PM
Modernceo
Modern Performance
Jul 22, 2005 02:14 PM
