Retrofit question
Retrofit question
I picked up a set of retrofits off a member they needed work they were made by smartdude24 or something along that line.. But he wired them and I'm a noob at wiring the light up but no highbeams and no turn signals... I think there e55 projectors and shrouds .. Stock BMW bulbs and ballasts any ideas
Hey easiest thing to do is pick up a wiring harness from here.
Bi-xenon: 9007 - Relay Harnesses from The Retrofit Source LLC
It is basically plug and play. You just have to wire ends from the harness to the solenoid wires on the projectors. Two wires may have to be swapped to make everything work but very easy install. If you pick it up and have questions give me a PM and I can help you out. Hard to work with someone elses wiring.
Iceberg
Sep 29, 2015 12:33 PM
