Complete Foglight Kit - 2.2L Interest Thread
You could wire them up factory if you want. You need to run a wire from pin 54 on the C1 BCM connector up to the C1 pin in the PDC under the hood. Once you've done that, you will need to integrate a positive lead from where the relay would be if you were already set up to have fogs, if not you will need to buy some.
You will need the switch... and do a little wiring. In most cases, the switch to BCM wiring and switch bracket is already there. You will just need to plug it in, and make the hole for the
This bit will make a perfect hole for the switch.
I'm too lazy to make the callouts... plus I'm at work.
Once you've done all this, you will need to get your PCM programmed to see the new fog circuit and activate the dummy light on the dash when on.
THEN WHAMMO!!! Factory fogs.
Blazer Fog Light Retro - Club RSX Message Board
http://www.customlightz.com/?p=p_150...ight-retrofits
Elaborate.
u pretty much got it. i was hoping they could do like package deal with hids and ballasts and **** with them. im not sure what it requires to mount them in the stock location. ill take a look in the summer. maybe a mounting bracket or something if its needed also. i think itd be a big hit.
but as u can see from this thread
https://www.cobaltss.net/forums/appe...teaser-235186/
those blazer fogs r pretty badass
for those too lazy to click the link heres the output
