Custom Gauge Pod
Old May 21, 2009 | 10:33 PM
Mattman6's Avatar
Custom Gauge Pod
Well I have always wanted an A-pillar gauge pod. So this week I decided to get the supplies together and get it started. I started off with a universal gauge pod from autozone...It did not fit what so ever and I had to cut quite a bit off to get it to even fit right. As you can see in the pics...these were just to get a test fit and to see how I wanted mount the pod onto the pillar.
After hacking the pod up and finally getting it to where it would fit right on the a pillar. I took some plastic glue weld and glued it to the a pillar. Then I took fiberglass bondo and went to town on it. Just used it to pretty much cover in the holes and to get it attached to the pod.
Then I sanded the hell out of it till it was somewhat smooth and no longer had all the bumps in it. I then took regular bondo and used it to make the edges a lot smoother and to cover in the imperfections that fiberglass bondo makes. After sanding and rebonding it a few times, I took some primer and threw a few coats on. The primer helps with seeing where imperfections are in the bondo and aid in sanding. So this is where I am at as of now.
It still needs a little bit of work to get done..after I get done I will be spraying it with a wrinkle black paint to make it look some what like the other a pillar. Comments welcome!!
Old May 21, 2009 | 10:43 PM
znew's Avatar
nice man
very creative!
Old May 21, 2009 | 11:23 PM
Mattman6's Avatar
yeah..it needs a little bit more sanding..but for the first time doing this and with what i started with i am pretty happy.
Old May 21, 2009 | 11:45 PM
Gestapo007's Avatar
good project. this seems like alot of work though lol
Old May 22, 2009 | 09:42 AM
Mattman6's Avatar
it really isn't all that much work...just a lot of patience
Old May 22, 2009 | 10:11 AM
hailcesar75's Avatar
Nice work. Better to make than buy it.don't know about you but when I make something, It feels custom to me
Old May 22, 2009 | 04:56 PM
Mattman6's Avatar
oh yeah...i know exactly what u mean man
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
