custom tail lights
Old Dec 28, 2008 | 03:36 AM
nikebaseballx00's Avatar
buying a red 912 or 921 bulb is easy.
is it, or are u being sarcastic?
Old Dec 28, 2008 | 03:39 AM
EmperorJJ1's Avatar
http://motors.search.ebay.com/search...trypage=search
Old Dec 28, 2008 | 03:41 AM
ok cool, so i could just upgrade the outer 2 to LED, and then get the inner reverse lights in red LED and rewire them to the outer lights
probably gunna get working on this when i get some extra cash and time
Old Dec 28, 2008 | 03:53 AM
EmperorJJ1's Avatar
that still wont have the same effect as the vid u posted. close thou
Old Dec 28, 2008 | 04:35 AM
how would it be different, the inners would be wired to the outers so they would do the exact same thing
Old Dec 28, 2008 | 04:52 AM
EmperorJJ1's Avatar
sadly no. the outers are going to be either led or filament but light up the entire housing. So the parking light lights it half way with the brake/turn signal making it brighter. The inners will have a red small circle that will do one of the 2 parking light or turn signal and possibly the halo doing the second one
the vette you posted had both sides with the halos as running lights and the center of each the brake/turn signal
i have thought this over way too much for my own use so trust me
Old Dec 28, 2008 | 08:30 AM
NCC-2000's Avatar
I did something similar to my tails, but the brightness doesn't match well since the strips I used on the inners are much dimmer. They can't really be seen during the day but at night they're ok. I have a few ideas kicking around in my head but I need to find LEDs that are bright enough to match the outer lights to make it work.
http://www.youtube.com/watch?v=L8DE6WtUm-I
Old Dec 28, 2008 | 10:33 AM
TheCaptain's Avatar
I have tails that do as you describe, the Corvette style full brake, turn, and park lights.
They come in FIVE different styles from GMAddiction (Cobalt-Addiction). And they come with the wiring to do everything, with simple male/female connectors.
https://www.cobaltss.net/forums/appearance-48/led-tails-%2A56k-maybe%2A-93397/
Daytime pics to show the middle does stick out a bit.
https://www.cobaltss.net/forums/show...light=led+tail
Old Dec 28, 2008 | 10:39 AM
Acey's Avatar
SC guys should put some bright ass LED's behind the rear lip as reverse lights.. Vette style... would look sick.
Old Dec 28, 2008 | 02:36 PM
no i dont want it like that with the halos
just i want the lights, so i would only replace my 2 tail lights and 2 reverse lights with some red LEDs
then rewire the inner lights to the outers. there would be no halos
https://www.cobaltss.net/forums/showthread.php?t=93397
those are exactly what i want, just not in that style of light
Last edited by nikebaseballx00; Dec 28, 2008 at 02:36 PM. Reason: Automerged Doublepost
Old Dec 28, 2008 | 02:49 PM
  #36
yellowltcoupe22's Avatar
ok what you need is two led strips to go around the inners, you'll need 2 adjustable resistors to be able to dim the lights down for the runnin light part and 4 diodes to keep power from tryin to go backwards throu the two wires goin to the lights. hold on a minute and i'll find the how to on it. i've walked another guy on here throu it. as far as matchin goes. get a set of led tails like i have. they look just like stock outters but have leds in them.
Old Dec 28, 2008 | 02:52 PM
  #37
jefferyss's Avatar
try this 1
https://www.cobaltss.net/forums/show...ight=jefferyss
why dont you just get a set like the captain has and swap the lense to your o.e.m ones?
Old Dec 28, 2008 | 03:17 PM
  #38
Originally Posted by jefferyss
try this 1
lot of money lol
im gunna get 4 LED strips and put them in all 4 lights
wire the LED strips to the brake light and turn signals
then replace the reverse light with a red bulb and wire it to the running light only
so the 4 stock lights will be running lights only, the 4 LEDs will be brake/parking lights only
Old Dec 28, 2008 | 03:24 PM
  #39
ok here it is. read the entire thing but the main parts i said before starts at post 62. the guy o rigami78 explains how to do the wiring.
https://www.cobaltss.net/forums/show...l+light&page=2
Old Dec 28, 2008 | 09:39 PM
  #40
TheCaptain's Avatar
try this 1
You can't swap lenses out, but IPCW does have two sets that look like stock. One normal red lenses, and one red and smoked lenses.
Old Dec 28, 2008 | 09:46 PM
  #41
mrsilent13's Avatar
sound like your going for the corvette look where they both run and blink when you turn....you need a resistor to add to both sides since you will be taking the power from both your outer lights...and you will also need...a diode i believe....and of course some kind of light inside the inner lights...since the only light in them is the back up light
Old Dec 28, 2008 | 10:21 PM
  #42
why would i need a resistor and diode?
why couldnt i just tap it into the original tail lights considering those already have all that **** wired into them
i know what im saying is probably hard to understand, does anyone have a wiring diagram for the rear tail lights/reverse lights that i could maybe do a photoshop of
the outer dots connected by a thin red wire are LED strips, and the big red dots in the middle are the stock lights
i am going to worry about doing something else for the reverse lights at a later date
Last edited by nikebaseballx00; Dec 28, 2008 at 10:23 PM. Reason: Automerged Doublepost
Old Dec 28, 2008 | 10:39 PM
  #43
mrsilent13's Avatar
i forget right now...i remember i had it saved...but im on a work computer...so ill post up when i get home
so what are you going to do without a reverse light?
Last edited by mrsilent13; Dec 28, 2008 at 10:39 PM. Reason: Automerged Doublepost
Old Dec 28, 2008 | 10:43 PM
  #44
i might just find like a cheap set of fog lights and mount them under the bumper so they shine down and create a glow..... idk yet but i will work it out
but with that diagram, would it work? i wouldnt need resistors/diodes because i would have 2 separate lights working
Old Dec 28, 2008 | 11:25 PM
  #45
mrsilent13's Avatar
looks like it should work
the way i was planning was using one led strip thats y i said resistor and diode
Last edited by mrsilent13; Dec 28, 2008 at 11:25 PM. Reason: Automerged Doublepost
Old Dec 29, 2008 | 12:01 AM
  #46
jefferyss's Avatar
why dont you try and mount 2 led white lights into the stems on your spoiler? that would look bad ass if you found the right lights to put in there imo
Old Dec 29, 2008 | 12:13 AM
  #47
possiblity
im gunna start the reverse light project after this one gets finished
Old Dec 29, 2008 | 12:22 AM
  #48
jefferyss's Avatar
if you read my write up ...i just spliced wires to make my inners as running lights only. the colors tell you wich is for the running lights. the other wire would in theory be for the brake/turn signal light.good luck
Old Dec 29, 2008 | 12:23 AM
  #49
yea i remember seeing that in there
probably gunna re tint mine while they are off
Old Feb 22, 2009 | 03:27 AM
  #50
hossdeuce's Avatar
just split two wires from the center brake light to the reverse lights and when you brake, the reverse lights will light up, but only the outsides would be turn signals. thats what i did
ps, go into your fuse box and replace the 10 amp fuse for the brakes to a 20 amp (if you wanna ensure it wont blow put a 25 amp in)
