diff between wax and polish?
Old Apr 22, 2007 | 03:32 PM
VeNoM0713's Avatar
just as the title says, could i use one or the other? if i used the polish after the wax will it make my paint shine more? i just dont know the differance between the two.
Old Apr 22, 2007 | 03:48 PM
SKCobalt's Avatar
Polish is an abrasive that actually smooths your clearcoat somewhat (higher grit than sandpaper for the most part). Wax is used to coat and smooth the surface. You can use both, but polish first and then wax.
Be carefull in what polishes you use, buffing pads, and rotary tools that you use because you can eat through your paint pretty quick if you are not carefull. The best method with polishes is to take your time and go slow.
Hope this helps
Old Apr 23, 2007 | 11:13 PM
VeNoM0713's Avatar
Hope this helps
ok well i wash my car first a couple times, and then claybar it and then i finish it off with wax. now if i did wash, claybar, polish and then wax would i notice a differance because i used the polish or no? and this would all be done by hand.
Old Apr 23, 2007 | 11:14 PM
Jackalope's Avatar
Polish makes it shine and the wax seals in the shine.
Oct 20, 2015 09:56 PM
cavfiredesire
Oct 3, 2015 08:02 PM
z28addiction
Sep 28, 2015 12:03 AM
grampss
Sep 27, 2015 08:51 PM
The Rookie24
Sep 14, 2015 07:03 PM
