do you re-install your high-rise? ENTER!!!
Old Mar 8, 2010 | 05:02 PM
averagewhiteboy's Avatar
Hey guys,
So, I'm having a bit of an issue. My car was factory low-rise. I swapped trunks for a high-rise. I then removed the high-rise and ran spoiler-less (with holes) for awhile. I then re-bought a high-rise and re-mounted it. Here's where the problem begins..
The first time I mounted it, the tape didn't stick at all. I'm using the 3M adhesive by the way.. I was told that it was because it was cold. Ok, fair enough. So I put the car in the garage, super taped it back up, mounted, etc. I had stuff on it weighing it down overnight. I came back out, and the one side is real on there, and the other side is half stuck down. So the one side is fully stuck, and the other side is slightly moveable. It's not a real big deal, it's just highly aggravating..
What did you do the mount the spoiler successfully? I figure that mounting a low-rise would be easy because you can actually put weight directly on the top of the posts to be mounted.. But you can't on the high-rise because of the top piece and the design.. I'm in a bit of a tizzy over it, and I'm highly considering just ripping it off - again..
Help!!
Old Mar 8, 2010 | 05:14 PM
07cobalt2.2's Avatar
wish I could help, I removed my low-rise and just slaped on my highrise all in about a hour, and never put weight on it or anything, was you wind brand new from gm? or did you put diff adhesive on it?
Old Mar 8, 2010 | 05:21 PM
I put my own adhesive on it because it was used.. I removed all the old stuff, prepped, etc..
Old Mar 8, 2010 | 05:25 PM
hmmm hope you get it figured out! I just slaped mine on after a quick scrub down with a little soap and water. it has held fine now for about 5 months haha, hope it stays that way!
Old Mar 8, 2010 | 05:30 PM
It isn't going anywhere, but when you lift up on the not as stuck down side, it pulls up a bit. Most people wouldn't care, but I'm very picky about stupid **** like that..
Old Mar 8, 2010 | 05:41 PM
ohh i know what you mean, I'm picky about that type of stuff also!
Old Mar 8, 2010 | 06:33 PM
Nighthawk243's Avatar
Are you using 3m VHB (Very High Bond) tape?
Old Mar 8, 2010 | 07:38 PM
GSDIESEL300's Avatar
just make an outline around the base of the spoiler with the 3 m tape and on the inside of that put a thick layer of silicone gasket maker. thats what i did, worked like a charm. good luck
Old Mar 9, 2010 | 09:29 AM
Yes, it's the industrial grade 3M.. I also used automotive sealant as well (glue type thing) inside the crevices that I couldn't get tape to fully cover.. The one side is fine, but for some reason the other is not.. I think I'm just gonna pull it off today and go from there.. Might put it back on.. May not..
Old Mar 9, 2010 | 11:33 AM
Urban Rogue's Avatar
shouldnt the wing be bolted down???
Old Mar 9, 2010 | 01:40 PM
BULLETSSMOKE's Avatar
The wing is bolted down yes but there is still wiggle room no matter how hard you tighten the bolts. Thats why you need the sticky stuff or whatever your choice is, i have to do this so i dont have a wobbly ass wing when i drive to Panama city beach on saturday for spring break!
Old Mar 9, 2010 | 01:51 PM
mkulrey13's Avatar
remove the center peice, this will allow you to put weight on the post. Thats what i did anyway..
Old Mar 10, 2010 | 01:38 AM
How do you remove the center piece? I removed the spoiler tonight at work, but if I get a solid way to install it without it being fucked up again, I may..
Old Mar 10, 2010 | 02:04 AM
Pop off the side panels, undo the bolts. The side panels are taped on, so you'll have to get the floss out.
riceburner
Sep 30, 2015 03:54 PM
grampss
Sep 27, 2015 08:51 PM
JonyyB
Dec 7, 2004 12:01 AM
