Door handle mounting clip broke. Need P/N
I went to open my door and the whole inside handle just popped out of the door panel, which then cracked.
I took off the door panel (epoxy'd the crack), and there's a little square hole in the door frame where a press in metal clip is supposed to be. The clip has a threaded hole in the middle and that's what the screw holding the inside door handle screws into. Well, my clip broke. Anyone know where to get another one? Thanks.
Flash
I took off the door panel (epoxy'd the crack), and there's a little square hole in the door frame where a press in metal clip is supposed to be. The clip has a threaded hole in the middle and that's what the screw holding the inside door handle screws into. Well, my clip broke. Anyone know where to get another one? Thanks.Flash
n20saturn
Sep 30, 2015 12:26 AM
