driver side hid problem
Old May 27, 2010 | 12:17 AM
zackss's Avatar
well i the kit i got was off of vvme.com as a gift so i figured a problem would be coming eventually. my driver side headlight won't come on so i ordered a new set of bulbs and that wasnt the problem so i ordered a new ballast and it still won't come on.. ive checked all the connections and i'm running out of ideas.. why would the passenger side still come on?
Well damn no ideas?
Old May 27, 2010 | 12:20 AM
outtamymind's Avatar
i dunno but i have a problem with my drivers side as well, already replaced the ballast and from time to time it won't come on until i flick the high beams on and off
Old May 27, 2010 | 09:59 AM
wantedSS/TC's Avatar
check your ground. it has to be on metal to metal plate.
if you hear the buzzing sound coming from the ballast then you know the ballast is working.
double check the connections. polarity on these kits can sometimes be opposite so you may need to flip them around.
Old May 27, 2010 | 10:36 AM
operatic's Avatar
Well damn no ideas?
Is it running off a relay harness? I know some of the older 3-fuse style relay harnesses we had, had separate left-right-battery fuses.
Or if it's a headlight kit, check the headlight fuses. There should be separate fuses for the passenger and driver's side.
Old May 27, 2010 | 10:46 AM
mkulrey13's Avatar
Running a relay harness? Could have gotten wet and corroded the connections.
Old May 27, 2010 | 08:35 PM
zackss's Avatar
i checked all the connections and fuses and everything seemed good, the kit i have has a relay but everything seems alright but the ballast on that side wasnt making the buzzing sound so i ordered a new ballast and it doesnt make the buzzing sound either.
so i think it might be a bad connection. i'm gonna check it out tomorrow if it stops raining
Old May 27, 2010 | 08:43 PM
TommyP's Avatar
AWD > FWD
It's not gonna buzz if the relay is bad. Not only could have the connections on the relay could have gotten wet, but if water got inside the relay itself the relay could be bad as well. I would replace that next.
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 04:49 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Tupp
Sep 30, 2015 08:18 PM
