Factory antenna removal?
Also good advice on the rag. I got teeth marks all over mine.
Makes my decision to shave it sometime soon that much easier.
yeah dont do it too hard else you break the screw off like i did. i was able to press the pinch welds back in though, and ended up taking the head off a bolt, drilling and tapping the antenna base, and finally putting it all back together. a five minute job turned into a few hours.
i ripped my aluminum bracket apart.... yea that sucked.... so basically you can blame GM. THey have an aluminum post with a steel antennae mast, different metals cause accelerated corrosion so the threads will rust out.... And the bracket gives LONG before the rusty threads....
how did you remove the bracket? it's in my way and it's useless now that the welds are broken...
also I'm wondering is there a way to take the whole assembly out and THEN separate the base from the antenna mast once it's out of the car?
thanks
I got my antenna thing situated. And its pretty light compared to stock, so it holds fine without the bracket.. But anyone have a good solution to re-attach the bracket to the antenna base?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
importkiller
Sep 30, 2015 07:18 PM
