Factory Fog Lights - HOW TO
Old Nov 1, 2009 | 08:52 PM
09blackonblack's Avatar
Thumbs up Factory Fog Lights - HOW TO
ok to start with there are serveral people who like to spread mis information and break peoples spirits...this will bring back some peoples spirits
step 1. disconnect the battery both positive and negative
step 2 pop the hood
step 3 remove the fuse box cover thats in the engine bay
step 4 take a 7mm and loosen all the bolts in the fuse box
take a 10mm and remove the positive aux power post
step 5 unplug the wire that loops up and over into the fuse box
step 6 open the tabs on both sides and the back and lift straight up then loosen the 7mm bolts the rest of the way
step 7 set the fuse panel aside
step 8 remove the ecm
step 9 unbolt the fuse box bottom there are 2 13mm bolts that hold it that are located under the ecm
step 10 remove the coolant resevoir
step 11 remove the headlights and the brackets
12 start on the passenger side and start unclipping the headlamp wiring harness and installing the new one with the fog lamp plugs as you go it makes it easier self explanitory there put new one the same way the old one was
13 clip new fog lights into the ss bumper or lt bumper with fogs and plug them in
14 reinstall the headlamp brackets and headlamps
15 reassemble the fusebox with the new harness instead of the old one just follow steps 10-3 backwords
16 remove panel under dash and remove silver trim with the dimmer switch
17plug in dimmer switch and new fog lamp switch
18 hook your battery back up
19 enjoy your new foglights
note: i am NOT resposible if you screw up your car. idk if this works on all the cobalts but i know it works on mine
there is an extra plug on the wiring harness i believe for the intercooler pump either cut it off or ziptie it out of the way
not all cobalt bumpers can use factory fogs because GM cut the tabs off the ls/lt bumpers supposedly
this project isnt that expensive with used parts
the fog light trim panel... is obsolete none at any dealer in the USA
i will get pics asap i start work at my new job tomorrow so it might be friday before i can get pics.
also with the lights on it doesnt light up on the cluster that the fogs are on... im going to check into this some more and see what needs to be done for that light... im thinking maybe just a light bulb back there.
hopefully this will make a sticky because it is very useful info and will help several people
Old Nov 2, 2009 | 02:06 AM
vortecz71wv's Avatar
Very well done! Thanks for the info!!!!!
Old Nov 3, 2009 | 12:06 AM
your welcome hope the info i gave you in the pm helps you out
Old Dec 30, 2009 | 01:40 AM
evZO6's Avatar
Did you ever get the light in the cluster to work
Old Dec 30, 2009 | 09:24 AM
never messed with it because no one had interest in this how to
Old Dec 30, 2009 | 12:44 PM
evZO6's Avatar
Well I will bring back the interest. Where did you get the wiring harness and stuff do this build?
Old Dec 30, 2009 | 06:26 PM
Icydub's Avatar
Check ebay, I know there are some there
Old Dec 30, 2009 | 08:32 PM
i bought the harness from grog1371 i believe was their ebay id they only have 8 left and its oem i believe
Old Dec 30, 2009 | 10:20 PM
PsychoCam's Avatar
Is it possible to wire it in a way that the light on the dash will work???
Old Dec 30, 2009 | 10:56 PM
well since i dont have a job now... i will investigate tomorrow and see whats needed for that
Old Dec 30, 2009 | 11:08 PM
PsychoCam's Avatar
ok sounds good to me haha
so why do u have to take the fuse box out?
I got confused.
what exact wire do u need to tap into and why that wire?
Old Dec 30, 2009 | 11:13 PM
evZO6's Avatar
sounds good I have been looking to do this for awhile, it would be nice to have good handle on what to do before I start taking things apart.
Old Dec 30, 2009 | 11:19 PM
08G5GT2.4L's Avatar
So this is installing a new front lamp harness with fogs and running it to the factory location on the fuse block and installing factory switches inside the car? Thats why the fog light "light" isnt showing on the gauges. The gauge cluster is controlled by the BCM and since the fogs were not factory the BCM doesnt know they exist or that there even on so the light doesnt show up.
Old Dec 31, 2009 | 02:12 AM
Icydub's Avatar
This is what I did..
Run a wire from each fog light to each headlight
You can pick parking light or low beam, whichever you want
or you can run the wires to your own button with its own fuse
To get the fog light to show up in the DIC you need to go to a dealer so they can reprogram it
Old Dec 31, 2009 | 05:15 AM
yeah its a whole new front lamp harness. thats why the fuse box needs to come apart. and ok i wasnt sure about the light, i need to install my switch panel anyways lol my switch is just in my cubby hole loose bc i never had time to mess with it
Old Jan 8, 2010 | 12:32 AM
evZO6's Avatar
any update on this bump.
Old Jan 15, 2010 | 11:09 AM
LSKid's Avatar
Headlight harnesses w/fog are different: 15854009/05-06,15886612/07,20760563/08+
Old Feb 22, 2012 | 04:46 PM
blu3_v1p3r's Avatar
any way can take a picture of the harness that is behind the dash? I looked back there and i only seen 1 that had a few green wires going to it, but not plugged into anything. I have yet to really dig around in there and check really good, but i figured the harness would be out in the open
Old Mar 19, 2012 | 07:34 PM
LtDanBoostdG5GT's Avatar
I have a 2009 Pontiac G5 GT with Fogs...... I need a New Harness that plugs the Fuse Box in to all the Headlamps, fogs, sensors etc... Which Part Number do I need?
The Tag on the Current Tag is Below.
Old Mar 19, 2012 | 08:41 PM
cobaltalex's Avatar
Sub'd
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 04:49 PM
importkiller
Sep 30, 2015 07:18 PM
cw383
Sep 30, 2015 12:41 AM
