fastflash issue
hello everybpody i have a fast flash issue wif my balt i replaced all of my blubs with new standard blubs when i hit the turn signal switch for the left and right direction they rapid flash but when i hit the hazzard the all blink normak im like wtf mabu its the turn flasher relay if there is even sutch a thing cuz all of my fuses are good and all hmmm
thanks
thanks
Standard bulbs you say? Did you get a type with a lower power draw?
Anyways, as far as hyper flashing not occurring on the hazzards, that is by design. The hazzard flasher part of the BCM ignores the bulb burn out check.
^^^ regardless of that or not the flashers would still flash faster because of the low resistance.. u kinda countradicted your self on that one and as far as i know their are no "low resistance" bulbs sold so no theirs no "lower power draw"
before you do anything you need to figure out why the bulbs are hyperflashing did you replace the bulbs with leds? if so then yes you do need to add resistors. If the bulbs are just standard bulbs, then theirs another issue.. if its still under warranty, then take it to the dealer.. problem solved
LED's for example draw very little power. The BCM module is what controls our flashers, not a separate flasher unit like in older vehicles. In the BCM programming for the regular turn signals, is a function programmed in that checks to see the resistance on the circuit. If the resistance is very low, the BCM will hyperflash the turn signals to indicate that a bulb is out. When you trigger the hazzard flashers, the hazzard flasher circuit bypases that bulb out check function in the programming, therefore making it flash at a 'normal' rate, regardless of the bulb status.
sorry about that then bro.. but regardless if the BCM had that feature or not, the turn signals should still hyperflash (my 97 Neon did it) or on some vehicles the turn signal just stays on and doesnt flash, because the circut is never completed.
