fastflash issue
Old May 8, 2010 | 01:22 PM
dodgekiller's Avatar
Exclamation fastflash issue
hello everybpody i have a fast flash issue wif my balt i replaced all of my blubs with new standard blubs when i hit the turn signal switch for the left and right direction they rapid flash but when i hit the hazzard the all blink normak im like wtf mabu its the turn flasher relay if there is even sutch a thing cuz all of my fuses are good and all hmmm
thanks
Old May 20, 2010 | 06:03 AM
RA081024's Avatar
i know this is an old post, but it wont be the relay, because it would effect the flashers also. did this happen b4 you replaced ur bulbs?
Old May 21, 2010 | 01:23 PM
constantproject's Avatar
sounds like a bad bulb/low resistance bulb
Old May 21, 2010 | 06:59 PM
RA081024's Avatar
that what i was thinking, however if the problem was happening before the bulbs were replaced, then it has to be wiring.
Old May 21, 2010 | 07:07 PM
JshLnsctt's Avatar
I have the same issue because I switched to all LED, it's most likely the resistance
Old May 21, 2010 | 08:40 PM
Nighthawk243's Avatar
Standard bulbs you say? Did you get a type with a lower power draw?
Anyways, as far as hyper flashing not occurring on the hazzards, that is by design. The hazzard flasher part of the BCM ignores the bulb burn out check.
Old May 22, 2010 | 03:14 AM
RA081024's Avatar
^^^ regardless of that or not the flashers would still flash faster because of the low resistance.. u kinda countradicted your self on that one and as far as i know their are no "low resistance" bulbs sold so no theirs no "lower power draw"
Old May 22, 2010 | 02:20 PM
couldebt i add some fender signals on the front fende rlike the bmw's got to slow down the flash ? or do i haft to add resistors to correct the issue
Old May 23, 2010 | 10:07 PM
RA081024's Avatar
before you do anything you need to figure out why the bulbs are hyperflashing did you replace the bulbs with leds? if so then yes you do need to add resistors. If the bulbs are just standard bulbs, then theirs another issue.. if its still under warranty, then take it to the dealer.. problem solved
Old May 24, 2010 | 01:35 AM
I did not.
LED's for example draw very little power. The BCM module is what controls our flashers, not a separate flasher unit like in older vehicles. In the BCM programming for the regular turn signals, is a function programmed in that checks to see the resistance on the circuit. If the resistance is very low, the BCM will hyperflash the turn signals to indicate that a bulb is out. When you trigger the hazzard flashers, the hazzard flasher circuit bypases that bulb out check function in the programming, therefore making it flash at a 'normal' rate, regardless of the bulb status.
Old May 24, 2010 | 05:00 AM
RA081024's Avatar
sorry about that then bro.. but regardless if the BCM had that feature or not, the turn signals should still hyperflash (my 97 Neon did it) or on some vehicles the turn signal just stays on and doesnt flash, because the circut is never completed.
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
