faulty ballast?
Old Jan 1, 2011 | 02:20 PM
brickloaf's Avatar
faulty ballast?
I have a 10k 3bspec kit and one of the headlights appears to be a little less blue than the other one...do you think that would be the ballast or the bulb that needs replacing??
Thanks
Old Jan 1, 2011 | 02:52 PM
Turbalt2010's Avatar
Thanks
switch the ballast from the one bulb to the other bulb and see if that bulb goes dim. if it does then it should be your ballast.
if it doesnt go dim, then its prolly your bulb.
tht would be my guess
Old Jan 1, 2011 | 02:55 PM
brickloaf's Avatar
good idea i never thought of that...I just emailed 3bspec so if they cant give me a definite answer ill have to try that...it just seems like a huge hassle
thanks tho!
Old Jan 1, 2011 | 02:59 PM
it is a pain in the ass to do, but it should give you the answer as to whats wrong with your hid kit.
also did you buy the relay harness?
the relay harness may help with this situation because it then will pull power directly from the battery.
good luck, hope you figure it out.
-ive bought 2 hid kits from buyhids.com and they are amazing
Old Jan 1, 2011 | 08:12 PM
brickloaf's Avatar
the relay harness came with the 3bspec kit...this kit has worked perfect for me until the past 2 months or so...although it seems like ive only had it for maybe a year and a half or so
Old Jan 2, 2011 | 07:12 PM
so then it deff has to be the bulb or ballast
Old Jan 7, 2011 | 10:23 PM
slobalt08's Avatar
I've had 2 different sets of hids in my headlights and both did the same thing on the same light I assumed this was normal
jcarroll53
Sep 24, 2015 07:43 PM
juandirtymessican
Oct 27, 2012 10:41 PM
AjSS
Mar 5, 2008 05:27 PM
BlkSdn
Dec 1, 2006 03:53 PM
JonyyB
Dec 3, 2004 09:32 PM
