Fixed Halop projector glow!
Old Apr 28, 2007 | 06:39 PM
cage's Avatar
So for all you who have that ugly glow in your high bean such as this...
Check you lights first. A few days ago i realized that when i took out my driver side headlight housing that the passenger side worked perfectly. So after checking the pongs in the dirver side and everything was straight realized that the wiring was incorrect from the factory.
Looking here the layout left to right is Orange, Black and Pink.
This is the corret way for the grey connector to be setup
https://www.cobaltss.net/gallery/fil...6/IMG_4254.jpg
What they did...
So just make sure that the left most wire of the grey connector (black wire in my case) is connected to the high beam light.
Again. make sure to test and see which headlight housing works when the other one is out. if one works correctly (i.e. high beam off, low beam on and vice versa) then follow that setup.
Hope this helps you all. Also now both low beam are the same strength. (B 4 driver low beam was duler than passenger).
Finished product...
Old Apr 28, 2007 | 06:43 PM
an0malous's Avatar
nice job man. hopefully this will help out others with the problem
+1 rep
Old Apr 28, 2007 | 07:11 PM
tombomb's Avatar
looks good! i hope mine dont have that glow, i have never really looked! thanks tho
Old Apr 29, 2007 | 09:17 AM
mkulrey13's Avatar
BINGO, and everyone told me i was crazy... i knew i was right
dieGone
Oct 1, 2015 06:27 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
jmelton327
Sep 26, 2015 10:04 PM
