functional CF hood-performance-problem ?'s
Old May 19, 2007 | 01:17 PM
chood711's Avatar
Whats up guys,
What I want is a hood similiar if not the invader 2 hood as seen on this site, 2nd hood down.
http://cobalt-addiction.com/exterior.htm
The only reason I want it is basically for looks. First question, When it says funtional that means you have to cut the bottom of the hood out right?
(for the next 2 questions when I say if not, I mean if the hood is functional and air is able to get in without any cutting)
Another questions is if not, would I be taking a risk of hurting something with the hood being functional? EX. water leaking through it and getting into something.
And another if not, could I expect any hp gains because of engine staying cooler?
Thanks in advance guys.
Old May 19, 2007 | 01:20 PM
laserblue2006's Avatar
Originally Posted by chood711
Whats up guys,
1. you shouldnt have to cut it
2. On that site it says comes with water channel. so if it loos like it is goin to rain then just slap that on and you will be ok.
3. It would be more of not losing hp. Heat soak kills hp numbers and this hood should help prevent it.
Old May 19, 2007 | 02:50 PM
Jase's Avatar
dont bank on the water channel
two of us got the hood and didnt get the water channel. Granted, anomolous got it from cobalt addiction, so it might be an add on piece but mine came from VISracing and i didnt get the water channel
The hood is already cut out. You can see the supercharger through the cut outs. And its rained here and the only thing getting wet is the supercharger.. I do have a little conern with that.. but it seems to be ok
Old May 19, 2007 | 03:45 PM
xspyder85x's Avatar
what does the water channel look like?
Extreme Dimensions
Pontiac G5 Appearance
Oct 28, 2015 01:52 PM
Extreme Dimensions
DocSvensk
Sep 27, 2015 02:24 PM
dennis69
Sep 23, 2015 02:56 PM
n20saturn
Tuning
Sep 7, 2015 11:56 AM
