Touch up Paint
Old Mar 12, 2007 | 11:36 AM
CobaltBurst's Avatar
Touch up Paint
The guy at the counter said to do it when it was warm..... what classifys as warm in VA? lol?
anyone know the ideal temperature to apply it?
Thanks,
Ryan
Old Mar 12, 2007 | 09:14 PM
YSUsteven's Avatar
many paints have directions that say apply above 60 F, common enamal spray paint.
I believe this is so that it drys in a couple of hours and not days.
Old Mar 12, 2007 | 09:17 PM
CTORANGESC's Avatar
Its was 5o yesterday in connecticut, and I painted eylids on my Balt, I used a hair dryer to dry the paint. It came out better tahn I thought. So.. I can say 50 is good
YSUsteven's Avatar
my touch up paint that came with my car is lacquer.
the solvent based paints should all be around 60 F
Old Mar 12, 2007 | 09:18 PM
Jackalope's Avatar
Usualy between 60 and 90 with low humidity and your just fine. Upper 50's and in the sunshine should be good too.
Old Mar 12, 2007 | 09:19 PM
YSUsteven's Avatar
just because the paint says 60 F, doesn't mean that it will not work fine.
And with the hair dryer it was prob 120 F
Old Mar 12, 2007 | 09:20 PM
blu3_v1p3r's Avatar
I paint aircraft for the Navy and our ideal temp for painting is 70 or higher, and not humid. If your using a two part paint, you an mixx the paint according to the temp. EX. If its cold where your painting you mix more hardener in with the pigmint, if its about 70 you mix it according to the instructions. Also you never want to use less hardner the the instructions tell you you to use.
Also where are you going to be paintin at? I hope a garage or shed....
Old Mar 12, 2007 | 09:24 PM
CTORANGESC's Avatar
But all I was trying to say was it was 50, and I made the paint work
Jackalope's Avatar
Force drying can cause it to lose its shine, be careful. I've had to re-do stuff a couple times cause I've flashed the paint dry and it comes out looking like a flat color. You can do it but like I said be careful.
Old Mar 13, 2007 | 09:57 AM
do they make a clearcoat touch up? b/c now the paint sicks out real bad at night b/c it is not glossy.... same in the day...
i mean its better then the bare metal that was showing but....
Old May 19, 2007 | 04:55 PM
DSMissed's Avatar
ya, you can buy a touch up clear, and thats what I'm gonna do, then buff the areas so it blends a little better.
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
riceburner
Sep 26, 2015 12:57 AM
Extreme Dimensions
Sep 24, 2015 07:51 PM
