Touch up Paint
I paint aircraft for the Navy and our ideal temp for painting is 70 or higher, and not humid. If your using a two part paint, you an mixx the paint according to the temp. EX. If its cold where your painting you mix more hardener in with the pigmint, if its about 70 you mix it according to the instructions. Also you never want to use less hardner the the instructions tell you you to use.
Also where are you going to be paintin at? I hope a garage or shed....
Force drying can cause it to lose its shine, be careful. I've had to re-do stuff a couple times cause I've flashed the paint dry and it comes out looking like a flat color. You can do it but like I said be careful.
do they make a clearcoat touch up? b/c now the paint sicks out real bad at night b/c it is not glossy.... same in the day...
i mean its better then the bare metal that was showing but....
