FX-R or Mini H1
Old Jan 5, 2011 | 11:16 PM
KyleGyger's Avatar
FX-R or Mini H1
Hey guys I wanna do some retro's once i get the money. i've never taken apart the balt lights before so im a little weary with cutting the housing. which is better for light output, cost, and labour. thanks a lot.
Old Jan 5, 2011 | 11:19 PM
samsumthing's Avatar
easiest would be the mini h1s. they really dont require any cutting to the housing at all and they clamp right in. the fx-r require alot of cutting and aiming. supposely the minis are just as good as the fx-r's, but ive never compared a set in person. cost would probably be the same, minis might be alittle cheaper.
Old Jan 5, 2011 | 11:21 PM
thedude411's Avatar
Bi-Xenon Output Comparison: TL, E55, Murano, FX, IS, e46,LR3
scroll thru that and figure out which one u prefer lol
Old Jan 5, 2011 | 11:22 PM
TommyP's Avatar
AWD > FWD
This. The FX-R is slightly better beam output wise to me. I like the FX-Rs a little better because they're a slightly higher quality projector, and they use a D2S bulb. Also don't worry about that foreground limiter, you won't even notice it when you're driving, it's mostly to keep light from shining on the inside of the headlight housing. If you're afraid to cut anything or don't have a dremel tool, get the H1s.
Old Jan 5, 2011 | 11:24 PM
heres the two:
fx-r
and the minis
you decide. did i mention minis also have a d2s version?
Old Jan 5, 2011 | 11:27 PM
KyleGyger's Avatar
okay thanks. so whats the difference between d2s and H1?
Old Jan 5, 2011 | 11:30 PM
TommyP's Avatar
AWD > FWD
It's essentially a completely different projector, the only thing in common is the name. It's called the D2S mini because it's the smallest D2S projector you can get.
Mini D2S
Old Jan 5, 2011 | 11:32 PM
nickadolph's Avatar
I would steer clear of the mini d2s for the time being. The H1 version was recently upgraded and from the link I would say the output on the H1 far surpass the the d2s version.
Old Jan 5, 2011 | 11:34 PM
thedude411's Avatar
bulbs... d2s has lots of brands of bulbs of high quality OEM stuff. easy to find. plus most of them use an AMP plug which allows for higher quality ballasts and ****.
KyleGyger's Avatar
who do you guys recommend? buyhid.com or TRS?
Old Jan 5, 2011 | 11:36 PM
thedude411's Avatar
buyhids can build them for u. trs gives u an amazing selection of build it urself parts
Old Jan 5, 2011 | 11:39 PM
i bought all my stuff from trs. you can call them and talk to them. they will point you in the right direction. if you're decide buyhids over minis, youre wasting your money.
Old Jan 5, 2011 | 11:41 PM
nickadolph's Avatar
This is the ouput your going to get with the buyhids retros, not very impressive IMO.
Old Jan 5, 2011 | 11:46 PM
TommyP's Avatar
AWD > FWD
not when comparing them to other retrofit projectors, but compared to aftermarkets, which is what they are priced to compete with, they're much better.
Old Jan 5, 2011 | 11:47 PM
nickadolph's Avatar
And as I mentioned in another thread, the bulbs for the buyhids projectors are a one off type that aren't readily available if you need them in a hurry, compared to D2S or H1.
Old Jan 5, 2011 | 11:48 PM
if my cutoff looked like that, i would probably just put the stockers back in.
Old Jan 5, 2011 | 11:49 PM
nickadolph's Avatar
Yeah I 100% agree with you on this. I just figure spend an extra $150 to do proper retros.
Old Jan 5, 2011 | 11:57 PM
thedude411's Avatar
agreed.. i doubt those have the ability to light up a dark ditch in the middle of the night.
the best thing that i love about my retros is how wide of a beam pattern they have... sure its nice to light signs and **** up way down the road, but its the deer and animals in the ditch that i need to see.
Old Jan 6, 2011 | 12:02 AM
TommyP's Avatar
AWD > FWD
and as a further comparison, Here's an output shot of the G1s that I currently have. You can see why I'm getting rid of them
Going from this
G1
to this
TL
Old Jan 6, 2011 | 12:49 AM
KyleGyger's Avatar
so i pay the 275 and then that comes with everything i need. i would get the halos so it will be 300.
Old Jan 6, 2011 | 12:54 AM
nickadolph's Avatar
Yeah, you might need some wire taps for the halos, and on trs if you spend more than 300 you get free led strip if you make note of them at checkout. As far as mounting the minis I'm not sure but you might have to just widen the hole a little bit, but nothing serious.
Old Jan 6, 2011 | 01:56 AM
elecblue06's Avatar
i say go H1 minis IMO they beam is much more even.. and are pretty much identical in width to the FXrs
they're the best bang for the buck.. stay away from the D2S Minis
the G1 PnP's are hit or miss.. just like the H1's different bulbs produce better results that being said it's 200 or so bux for a H1 mini.. lol and go with TRS they're win
Old Jan 6, 2011 | 11:02 PM
KyleGyger's Avatar
okay thanks guys. when you paint your stock housings, can you paint the reflector bowl? also how did you paint the housing black? spray paint or did you get it professionally done? if done by a pro how much did you pay.
Old Jan 6, 2011 | 11:16 PM
TommyP's Avatar
AWD > FWD
ya my reflector bowl is painted. I would just so everything blends together. Rattle can will work just fine.
Old Jan 7, 2011 | 02:56 PM
Cobalt08LS's Avatar
deffff not impressed in that cut offf at alll.
i want the minis but i just need the money and sumone to build them for meee
tcmini_S
South Mountain
171
Aug 22, 2006 11:28 PM
superchrgdPRINCESS
Jul 17, 2006 02:41 PM
WickedSS2005
Sep 26, 2005 03:29 AM
Vendian
Apr 23, 2005 01:27 PM
