gauge cluster swap
Old Jun 24, 2010 | 11:49 PM
FlyingLow's Avatar
gauge cluster swap
Is it possible to put a 160mph ss cluster in a LT? I'd like to have the ability to know how fast I'm actually going.
Old Jun 24, 2010 | 11:50 PM
TommyP's Avatar
AWD > FWD
ya it's possible. Actually I'm pretty sure it's a direct swap.
Old Jun 24, 2010 | 11:56 PM
Caligula's Avatar
I think the 2.2L tops out at 65mph. Unless your boosted. So why go thru the trouble?
SLOW THE EFF DOWN.
Old Jun 25, 2010 | 12:11 AM
TommyP's Avatar
AWD > FWD
SLOW THE EFF DOWN.
Troof, there's no way you should ever need to go over 120 in the 2.2. It's just not necessary and would take forever with that engine.
Old Jun 25, 2010 | 12:16 AM
exiged's Avatar
years must corrospond for it to work. IE: if you're a 2006 LT the Gauge cluster must also come from another 2006.
Old Jun 25, 2010 | 01:14 AM
FlyingLow's Avatar
Do I need to swap any sensors or is it simply a remove & replace procedure?
SLOW THE EFF DOWN.
Eventually a stage 2 ZZP turbo kit will work its way under the hood, so a speedo capable of keeping up with it is on the list.
I've had a lifted jeep for the past few years. The ability to go over 65 without going downhill is a newfound joy.
Old Jun 25, 2010 | 04:36 PM
Icydub's Avatar
Most LS/LT people buy the SS cluster for the looks. The stock 120mph looks ugly. The gray and red accent lines on the 160mphs gives a better appearance to the interior of the car. MOST SS cobalts do not travel fast enough (driving 120+ for more than 5 seconds) to create enough downforce from the high rise wing to have an effect. So why have it?
I dont think it can go over 110, i've tried
OP: The 160mph cluster needs to be the same year as your car. 07 SS will fit in a 07 LT. There is some speculation about 05-06 all compatible with 05-06 and all 07+ compatible with 07+. It may deal with digital signals and the change in models between the years (radio, DRL, steering wheel, etc). But to be safe, get the same year as your car.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
jmelton327
Sep 26, 2015 10:04 PM
