Gauge Pod
i already did basically. it's not something that's very hard. you get abs plastic easiest way is abs pipe from plumbing supply. then you cut small pieces off. go buy a little plastic container from michaels craft store for glue like etc. put acetone in there and then add ur chunks. in a few days it will turn into abs goo/glue. very easy. layers need to be thin if your thickening a piece or else it will never dry right.
i know its a old thread but for any of you that try to make one of these DO NOT HEAT THE ABS GOO WHILE ITS STILL WET AT ALL TO DRY IT. it will make it bubble up and **** up what you have done serverly.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ill let ya know. lol
