Gauge question.
Old Jul 14, 2012 | 01:37 AM
Smithkid21's Avatar
Gauge question.
So I have a quick question. I plan to get a 3 pod pillar from ZZP, and I want to replace my stock boost gauge. My question is, will this one be the same plug type? Or will I have to re wire it?
Thanks!
Old Jul 14, 2012 | 01:49 AM
CannonBalt's Avatar
Thanks!
You will have to rewire it into the vacuum line and power.
Old Jul 14, 2012 | 02:25 AM
Smithkid21's Avatar
Oh, I forgot to add, its this one, if it makes a difference. Auto Meter 4777 - Auto Meter Carbon Fiber Ultra-Lite Analog Gauges - Overview - SummitRacing.com
Or would it just be easier to get the mechanical one?
Last edited by Smithkid21; Jul 14, 2012 at 02:25 AM. Reason: Automerged Doublepost
Old Jul 14, 2012 | 02:34 AM
CannonBalt's Avatar
Both you will have to tap into the line
Old Jul 14, 2012 | 03:58 PM
Smithkid21's Avatar
Which would be easier though?
Old Jul 14, 2012 | 04:05 PM
CannonBalt's Avatar
I have digital.
Both you have to tap into the vacuum line like i said.. and power the backlighting. It's the same.. It all depends on what you're into..
One is more responsive than the other as well
Old Jul 14, 2012 | 05:34 PM
Smithkid21's Avatar
Hmm. Well then, I have a couple more questions. Which is more responsive/accurate? And where is the boost/vacuum line on the blower?
Sorry for all the questions, I just like to go into a project knowing how to do it.
Old Jul 14, 2012 | 11:31 PM
CannonBalt's Avatar
No problem man, Ask as many questions as you need. I learned the same way, by asking questions.
If you need anything else feel free to PM me.
I find the digital more accurate.. I hooked up my AEM Digital boost gauge, and a mechanical aem boost gauge.. and i found it was much more responsive.
The vacuum line comes from the intake manifold under the blower... it's the only black hose, and goes to the by-pass valve.
I've dotted the vacuum line in red. All you need to do is cut this line, and put the T-Fitting that is included with your gauge, re connect both sides of the cut hose to the T-Fitting, and run your new line through the firewall to your newly installed boost gauge, and of course wire the gauge for power.
If you need help with that, Again. Feel free to PM me.
Here is the Diagram:
Old Jul 15, 2012 | 02:48 AM
Smithkid21's Avatar
Ahh. I see. I've installed at vacuum gauge before in my old Grand Am GT, but it just confuses me on the whole "mechanical or electrical" thing. The one I did on my GAGT was mechanical, and I did the whole t-fitting dealio, and wiring it up and whatnot, I thought that electrical just went off of sensors, or something like that, just like the stock one does. Or is there something I am not understanding about it?
Old Jul 15, 2012 | 03:08 AM
CannonBalt's Avatar
My AEM One goes from the T fitting, Hose.. To a bung with a sensor on it, which then plugs into an electrical pigtail, which plugs into the gauge.
AEM Digital Boost Gauge -30 to 35psi 30-4406
Old Jul 15, 2012 | 03:05 PM
Smithkid21's Avatar
So basically the electrical one just has the extra bung and pigtail on it? Where as the mechanical one is just the hose?
Old Jul 15, 2012 | 03:34 PM
CannonBalt's Avatar
Yes
Old Jul 15, 2012 | 10:01 PM
Smithkid21's Avatar
I see. So i think after all this confusion, I'm just going to get the mechanical one, just cause its less expensive.
Old Jul 16, 2012 | 12:20 PM
Smithkid21's Avatar
I got another quick question. Where would be the best place to get the power from? I know there is the fuse panel on the passenger side, but is there a better place to find power?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Bohb
Sep 27, 2015 09:11 PM
Sep 27, 2015 08:53 PM
