Gauges
Old Feb 19, 2007 | 01:11 AM
ladd44's Avatar
Gauges
I have a few questions about guages and pods. I know there are a ton of threads actually 98 pages and i didnt wanna go through them all again.... So I have an SS/SC and im wanting to get some autometer cobalt series gauges. However, can we put the gauge pods on the A pillar? I have heard both yes and no.... And if you were going to get gauges what would you get?(i.e oil pressure, trans temp, boost.......) Plus I currently have a stage 1 kit in the car and lookin to going to a 2 pretty soon. Open to any ideas....
Thanks for the help
Old Feb 19, 2007 | 01:13 AM
stotte20's Avatar
yes you can aput them on the a pillar. cobalt addiction has a 3 guage pod out for the balt that can be color matched to the factory color i have it personlay and love it have a interceptor guage in it and a aem ugeo
Old Feb 19, 2007 | 01:15 AM
ladd44's Avatar
Ya i saw those but the issue i was hearing about was the fact that we have side airbags? It would interfere?
Old Feb 19, 2007 | 01:29 AM
Boosted_SS's Avatar
no i have the one from CA and i have side air bags and it works good. the only issues is that the top two gauges hit the plastic cover for the air bag and are pushed out about 1/8 inch but no biggie and it's barely noticeable. here's a few pics...
Old Feb 19, 2007 | 01:38 AM
stotte20's Avatar
are they the difi guages??? looks good btw
Asphalt Assault's Avatar
I have ordered an autometer triple gauge pod from Partsource (cdn) and I have a Wideband autometer gauge to go in it and plan on getting the Aeroforce. one day I will change out the boost guage to a mechanical boost. IMO that is better and faster in reacting to boost feed but more importantly it will give me a read for PSI not kPa (stock for Canada). impressive to say i have 130 boost though (18.5 psi). so that is my plan. the aeroforce gives many parameters through the OBD port. that guage is the easiest to install.
I would go with an AEM wideband only because I hear it works better with HPtuners. but if when I get HPTuners this spring and try to get it to work with the autometer wideband I will do a write up and try and get a yellow post it on it for the advance tuning section. AEM I now works well. just questionable right now for the autometer. in theory it should be no problem but we will see.
Old Feb 19, 2007 | 01:47 AM
Boosted_SS's Avatar
AC AutoTecnic gauges
Old Feb 19, 2007 | 01:48 AM
stotte20's Avatar
never heard of them but they look sweet.
Old Feb 19, 2007 | 02:19 AM
ladd44's Avatar
Alright ya sparked another question..... Whats the diffrence between mechnical and electronic gauges? And if I went with a pod from Cobalt Addiction it wouldnt affect anything?
Old Feb 19, 2007 | 02:25 AM
Boosted_SS's Avatar
electric gauges all the sensors are under the hood but with mechanical there is a line going into the car and screws into the back of the gauge. lets say you what to get the oil pressure with an electric gauge you have a sensor that screws into the block and a wire going to it that senses the current from the sensor and send the information to the gauge where a mechanical has an oil line going into the cab of your car and directly to the back of the gauge. if possable i would stay with electrical cause you don't want to run an oil line or something similar into your car and have it break. what a mess that would be!
not the CA pod won't affect anything
also when you wire them put the power wire directly to the red wire or pink wire or whatever color you want to call it that powers your boost guage. this will save you from running wires to the fuse panel and this way they turn on and off with you key. works great!
Old Feb 19, 2007 | 05:48 AM
Florida 76's Avatar
get the dual interceptor gauges its all you need.
Old Feb 19, 2007 | 04:54 PM
ladd44's Avatar
Okay so I want electronic gauges and prolly one intercepter and a boost but what other one or two in case i dont want the int. would be the most effective
Old Feb 19, 2007 | 05:00 PM
Boosted_SS's Avatar
i would say boost, oil pressure, and a wideband a/f ratio
i think i'm going to be getting my interceptor soon.
Old Feb 19, 2007 | 05:50 PM
A-Town's Avatar
looking good, mine will be installed this weekend. Cant wait!!
Old Feb 20, 2007 | 05:50 PM
ladd44's Avatar
How much is the install gonna run?
Old Feb 20, 2007 | 08:15 PM
What do you do for AFR wideband though. you need a input for that and I have asked around and the only way to do it is have a afr wideband with the out put to send to the Aeroforce but if you have to get the guage then just put it in your pod?
Old Feb 20, 2007 | 08:27 PM
Boosted_SS's Avatar
you can also drill a hole in the down pipe right before the cat and weld a nut onto the pipe to screw the O2 sensor into it and then run the wires. i never heard of your way but i'm not doubting it works
Old Feb 26, 2007 | 09:44 PM
IanWilson2007's Avatar
can you put the ss gauge faces on the ls gauges
Old Feb 27, 2007 | 11:41 PM
Boosted_SS's Avatar
i don't think you can because i believe the LS has a different max speed on the speedo
Old Feb 28, 2007 | 12:09 AM
TCarter's Avatar
Personaly, a Dual Interceptor Gauges, and a Wideband.
Old Apr 20, 2007 | 02:18 AM
hondakiller's Avatar
so putting a dual or triple gauge pod wont effect the side airbag? does it just go over it or what?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
