gen 3 headlights and hids...
you will want to do the anti-glare mod on those projectors, they do reflect some light above the cutoff line which is not acceptable once you put hids in them. here is a how to on that, https://www.cobaltss.net/forums/how-...ectors-114151/ I also used the "HID relay harness" from zzp which has a relay so you do not overload your stock wiring, since hids use more power. I have 3rd gen projectors with the h1 6000k hid and did not need to do any modification other than that. good luck with your install.
Edit: You will also need amber bulbs for your blinkers since the 3rd gens have a clear reflector
brickloaf
Sep 21, 2015 02:17 PM
