Gen 4 headlight issues
So I bought some Gen 4's on ebay about a month ago. After I put them in, I saw stress cracks on the inside of the lens on the passenger side only. Contacted the seller, sent it back and got a new one. Before I put the new one in, I took off the front bumper and made sure everything was lined up right. I've been checking the lense all this week and haven't seen any cracks until today. The passenger headlight is cracked again on the inside. Anyone have any ideas as to what's causing this?
I think there's an issue with my car. The cracks aren't from the bulbs. If it was the bulbs, then the lenses would be burned instead of cracked. Would a headlight bucket issue cause this?
Honestly, I don't understand how this can happen in the first place. It's beyond me. I still plan on buying the 4th gen projectors though since I already have an H7 hid kit.
Did you send it back & get a new one to see if it happens again?
my passenger side gen 4 did the same after a few days, my replacement set arrived last night. Putting them in at the same time as i install my HID's on monday hopefully so we will see how they do
Let us know how that goes. Which vendor did you get them from on Ebay? If you don't mind me asking.
You shouldn't have to force them into place. Try adjusting the headlight bracket and seeing if that makes them go in a bit easier. Just loosen the bolts for the bracket (There are a few, you'll need to remove the light), move the bracket a bit, then tighten down.
