Gen 4 headlight issues
so adjust the bracket until they fit in place? I see like a gap between the bumper and headlights. I'll try that once more. Gonna get my HID's tomorrow from DDM and try to line up the headlight brackets one more time. When I looked under my headlights, I saw the tab wasn't in place of the bracket. Kind of aggervated, but I'll give a shot one more time.
Tonight, I noticed the stress crack on my passenger side too. Someone pointed it out to me after we lined up the HIDS, and I was like "are you kidding me?" Its not that bad, but I guess it started from the halogens when I first got it. Put the HID's 35w in yesterday. Cleaned it, waxed it, so hopefully that will prevent it cracking from any further I hope tonight. Is there a place that sells lenses for the cobalt, incase I have to replace the entire lense? Can I get that link?
I'm figuring it has something to do with the heat. All it looks like is tiny bit of scratches inside the passenger light, which is barely notice, until your really close up to the headlight. Need to post some pics. No big deal, if they both start doing the same thing, just gonna use my stock lenses to replace them. Can't display image from photo bucket, don't know what I'm doing wrong. here is the link instead. If you look at it close its barely notice. It here the low beams are. http://s870.photobucket.com/albums/a...a.jpg&newest=1 How do you post pics here, do you have to do some special format for it to display? I took the link and post it in the url to insert image and its not displaying correctly. Why?
ughh.. this is not good, especially because i love how the gen 4's look and i just bought a set : ( i will be putting 55w hid's in them though.. so if its the heat, im sure my hid kit will start cracking them too. awesome..
so what are we saying here, if you use halogen bulbs then the heat will crack the lens cover, but if you use HID's then it wont? How so, why?
Also, if you have 4000k lights versus 8 or 12k, does it really matter at night when you're driving your vehicle? Basically, will a 4000/8000k HID light offer you any less brightness than stock halogen bulbs?
Thanks in advance for answers, I'm a newb in terms of projectors
HID is brigher than halogen. 4300K HID produces whiter light and has more output in lumens than 8000K HID. The reason 8000K hid is popular is because it is more of a blue color light.
crack kills
To me its not the end of the world. Just incase both lenses started both stress cracking, I'm gonna use my OEM lenses to replace the DEPO lenses. Saw some fog build up inside the Gen4's after a nasty storm, because one of my rubber pieces popped loose in the back to create moisture inside the headlights, so I took a hair blower to kill all that stuff off outside. Got all of it, but don't know if that will prevent them from the future run, not to fog up again.
i had my gen 4's on for pretty much a week and i too have these stupid hairline cracks on BOTH lenses. im honestly not even going to worry about it until it gets bad enough to warrant me to take these apart and put OEM lenses on them. i still love these projectors though.
you could be right but im running hids in mine also and im already starting to get the cracks.. but then again, i am running 55w hids so who knows
its a common problem dude, most people dont worry about it, its only noticeable when the sun hits it at certain angles. And if you plan to run HID's in them right away, theres a good chance you wont see this issue anyways
I bet one of those wet sanding headlight repair kits might work on them if you get the stress cracks.
thumbs up
