Going to Paint Engine Plastics....Few Questions
Old Sep 24, 2006 | 12:39 PM
laserblue2006's Avatar
Alright i am going to paint the fuse box cover, the cover right below it(atleast it is there on a 2.2), and the sparkplug cover. what types of paint do i need to get. do i need to use high temp paint on the spark plug cover? also i want it to look as muchlike my laser blue exterior as possible, so i was thinking about primering, sand, primer, base(silver with metal flake), use blue candy paint (until i reach the right color), wet sand, and then clear coat. I do have some experience with this stuff but it was all models and other small things, but i was wondering how many coats of each to put down?
Old Sep 24, 2006 | 01:50 PM
06cobaltls's Avatar
good question i am very interested in this information as well
Old Sep 24, 2006 | 01:53 PM
IMADreamer's Avatar
I did not use high temp paint under my hood and so far so good. I was worried it may be a mistake but to my knowledge sunburst orenge high temp paint doesn't exist so I made do with what I have. As for the process, it sounds like you have it right. Hit it with several (3) coats of paint and clear to give it some depth and all will be good. If you want your color to match exactly and don't use high temp paint you can go to the dealer and get the exact match.
Old Sep 24, 2006 | 03:39 PM
well i did it to the sparkplug cover. i didnt want to go with clear coat because i didnt want it to be high gloss. it is still drying and i will get more of it on the car when it is dry.
PICS:
Old Sep 24, 2006 | 04:29 PM
Alright here are some pics installed. next will be the fuse box and the plastic beneath it. also a intake will be on soon.
Pics:
Old Sep 24, 2006 | 04:44 PM
Belto's Avatar
dude that look great ,, you have to do a how-to on that ,,, many people will apreciate it
Old Sep 24, 2006 | 04:53 PM
REIGN SS's Avatar
Original Hayden Fanatic
painting plastics under the hood w/ spray paint will be fine, pastic doesnt hold heat for a long time. Automotive paint will be ok for most motor parts, i saw a guy that painted his SC w/ arrival blue paint, and it held well... if your doing spark plug cover, fuse box & what plastic what nots under the hood you'll be good w/ normal household paints...
Old Sep 24, 2006 | 04:56 PM
REIGN SS's Avatar
if you plan on painting plastic w/ automotive touchup paint you best to use a special type of etched primer for plastics
Old Sep 24, 2006 | 04:57 PM
i will tomorrow probably....if someone wouldnt mind sending me a picture of a stock sparkplug cover so i can show before and after i would appreciate it.
Old Sep 25, 2006 | 03:03 AM
06cobaltls's Avatar
Old Sep 25, 2006 | 03:04 AM
06cobaltls's Avatar
Originally Posted by 06cobaltls
just figured i would add some before pics for you, and by the way that looks awesome
Old Sep 26, 2006 | 02:21 PM
Belto's Avatar
I tried to do it but when I whent to take off the cover the hole **** came out,,, how do you separate it? how do you take it off??
thanx
Old Sep 26, 2006 | 02:42 PM
roccityroller's Avatar
mind if i ask what paint you used, that's almost a perfect match
Old Sep 26, 2006 | 04:36 PM
thanx
when you pull it off look on the bottom ther will be 3 shiny screws unscrew them and then pul th top off...also i would recommend setting the peice back on top of the motor to avoid dust and stuff
i used some paint i found at wal-mart called Anodize-It i will get more pictures and write a how- to when i get time.
Old Sep 26, 2006 | 04:57 PM
well im about to go paint the other stuff so i wiil be back with pictures
Old Sep 27, 2006 | 07:54 PM
srt4klr's Avatar
i painted pretty much anything i could take off under my hood,but before i started priming or painting i used a spray adhesion promoter it helps the paint stick alot better , just a suggustion , you can buy it at murrays or any parts store
Old Sep 27, 2006 | 08:09 PM
biohazard's Avatar
Get low
use some high temp clearcoat.... it wont gloss it up to bad i used it before my whole underhood area (fuse, intake, big plastic) was grabber green lol
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
riceburner
Sep 26, 2015 12:57 AM
