Good place to buy GM paint?
Old Nov 30, 2012 | 06:57 AM
cOHbalt's Avatar
So I have a sunburst orange metallic ss. With a dime size rust spot on that has been driving me crazy. I have bought stuff to remove the rust but before I do I was wondering if there is any good places to get the paint? (Online, or stores)
Old Nov 30, 2012 | 07:13 AM
reduf99's Avatar
sjc0013 Licks windows
Gm dealer
Old Nov 30, 2012 | 07:16 AM
cOHbalt's Avatar
Is there anymore places that would sell it?
Old Nov 30, 2012 | 10:56 AM
Dipped_Cobalt's Avatar
try your local shops, im sure cheaper, save time and shipping costs
Old Nov 30, 2012 | 11:13 AM
cOHbalt's Avatar
Funny thing is I checked autozone yesterday and they had all the gm paint but orange....
Old Nov 30, 2012 | 04:58 PM
joezombies's Avatar
What form do you want it In? If your wanting a quart or gallon size like you would spray with a gun then a lot of orielies can mix paint by code and I believe Sherwin Williams does too. WWW.tcoglobal.com is a site that sells paints and you can order by paint chip. If your looking for spray cans I guess just a local auto parts store that carries touch up paint.
Old Nov 30, 2012 | 06:36 PM
cOHbalt's Avatar
Just a can or touch up. But I can't seem to find a store around me but ill have to get some shipped
Old Nov 30, 2012 | 07:52 PM
joezombies's Avatar
And if its a rust spot you better sand it down and treat it first,not just cover it up with touch up paint or it may spread like cancer and the paint will just chip off anyways. Also the paint will not perfectly match cause there's clearcoat over the rest of the paint and I'm sure its faded from the sun so the touch up may stand out like a sore thumb depending on the area.
Old Nov 30, 2012 | 07:57 PM
LamboW9's Avatar
yea if your doing a tiny touch up then just take it to the dealer, if you screw something up you will end up paying more for it in the end. a lot of rust is more than just surface rust as well. better to get it fully fixed than just surface treated.
Old Nov 30, 2012 | 10:26 PM
cOHbalt's Avatar
That's a good thought ill have it in for a rust inspection at my dealer
Old Dec 1, 2012 | 12:19 AM
joezombies's Avatar
That's good. Better spend a lil now then cover it up and have headaches later. Just looking out for ya man. Myself I have guns and the equipment to sand it down and paint and fade it properly so not a big deal. Hopefully soon ill have my own shop to work in then next step will be to build my own downdraft paintbooth
Old Dec 1, 2012 | 12:34 AM
AzraelRaezier's Avatar
i work for sherwin williams, you have to go to a automotive specific sherwin williams location to get car paint.
Old Dec 1, 2012 | 02:38 AM
joezombies's Avatar
Thanks for the info. I myself have never boughten any at one just was told you could. I've mostly ordered mine online.
Old Dec 1, 2012 | 05:55 AM
cOHbalt's Avatar
Thanks man I appreciate that for real! And I bought this rust dissolver from auto zone. It's called loctite navel jelly. I'm going to give it a try on some rusty tools I have laying around to be safe but the guy at the zone said he uses it all the time. Any thoughts?
Old Dec 1, 2012 | 07:57 AM
joezombies's Avatar
Yeah that stuff is good at removing rust. They also sell stuff that neutralizes rust and turns it into a primer all in one,however I've never used it just been told about it.
Old Dec 1, 2012 | 09:07 AM
cOHbalt's Avatar
I saw the one that turns into primer as well. I'm just worried that when I do patch it up with the paint that it will be so obvious. Well... I guess it's only a dime size. Ill test it out on some scrap metal before
Old Dec 1, 2012 | 09:25 AM
joezombies's Avatar
Where is this spot located on the car? If its low enough it may not be noticed.
Old Dec 1, 2012 | 09:57 AM
cOHbalt's Avatar
It's real low under the driver door
Old Dec 3, 2012 | 06:33 PM
LamboW9's Avatar
u might be ok then. just be sure that you DO NOT tape anything off when you go to spray it with your color matched paint. if you tape it off it will just leave segregation lines you will literally need to fan it out (blending) after your patch. don't forget to seal the area with a good primer sealer as well before spraying, otherwise the paint will absorb into the filler area and it will be noticeable.
Old Dec 3, 2012 | 08:49 PM
TommyP's Avatar
AWD > FWD
If you go to a body shop, especially one that contracts out of GM dealerships, they can get you color matched PPG paint. PPG makes OEM paint for many car companies. Our dealership actually has a little scanner type thing that you put on the paint of the car, and it scans it and matches the paint.
ineedacobaltss
Nov 7, 2015 02:25 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
n20saturn
Sep 30, 2015 12:26 AM
jas09ss
Sep 26, 2015 01:06 PM
riceburner
Sep 26, 2015 12:57 AM
